Android 7.1 Radio: Canbus Functions Issues (VW/Fabia2 2008) - Display, Reverse & Parking Sensors
benekdp 15627 9
How can I fix an Android 7.1 VW/Skoda radio in a Fabia II so the dashboard display, reverse gear/PDC graphics, and CAN-bus functions work correctly, and how can I stop the screen from dimming with the lights?
The missing display and reverse/PDC functions are most likely a CAN-bus decoder/module compatibility problem, so you should try a different decoder and change the car model in the radio’s hidden CAN-bus settings. You can enter those hidden menus from Settings / About Device by tapping kernel version, then OS version, and repeating it 3 times [#17391102] One user with a similar VW/Seat setup fixed the problem only after using a different CAN-bus module; another said only the fifth decoder worked fully, even though it was not listed for the car and software updates did not help [#18889673] [#20513607] The digital speedometer may work without OBD2, but fuel level and handbrake status likely need OBD2 to be shown properly [#17391102] For lighting/illumination issues, one reply says the cause was simply wiring: connecting the orange wire from the radio to the yellow power wire fixed the button illumination [#21412994]
  • #1 17386533
    benekdp
    Rate: 26
    Hello, the matter is as follows ... I decided to buy a Radio on Android 7.1, in a set with a canbus module.
    Radio dedicated to VW cars, my car is Fabia 2 from the end of 2008.
    The first thing, after connecting everything as it should (I hope) that hurt me, is that the display between the meter and the speedometer has died - it should have a radio channel / track number and volume, and it is black.
    The second thing is that it does not catch my reverse gear and does not show me graphics with parking sensors and distance to the obstacle (it really hurt me so much :(
    In general, these things only show me the door / flap opening, total mileage, battery charging, and everything else is nonsense, e.g. Handbrake always in the ON position, the amount of fuel in the 127L tank, zero speed, zero speed etc.
    I do not care about the parameters about which I wrote the paragraph above as much as on parking detectors and the display between the clocks.
    I haven't connected the webcam at the back - yet, of course, when I connect it and have a picture from the camera + a car with detectors drawn, I will be very happy.
    I read somewhere that you can change the car code in such radios, or change the CAN software ... but for no treasures I found how to do it.
    And one quick question to be sure ... When the lights are on, the radio automatically reduces the brightness, connecting the ILL cable will do the trick?
    Thank you beautifully for all the help and advice
    Radio, what is under the link differs from mine only by symbols on analog keys, all others look the same.
    https://allegro.pl/radio-android-vw-skoda-seat-kamera-nawigacja-gps-i7214261625.html#thumb/10 " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://allegro.pl/radio-android-vw-skoda-seat-kamera-nawigacja-gps-i7214261625.html#thumb/10
  • #2 17391102
    benekdp
    Rate: 26
    Hello again, it's a shame that no one was able to advise me anything, things I came to (maybe someone will be useful :)
    the display between the speedometer and the tachometer when he died so did not stand up.
    After connecting the reverse camera after driving in reverse, of course the image from the webcam appears, and as I approach the obstacle and the sensor starts to pick up, a car with sensor lines appears on the left :) (Happy)
    I found hidden menus - you can't enter them with buttons, you have to go to Settings / About Device and click kernel version later OS Version and repeat the action 3 times. (there are some nice options inside, e.g. changing the car model for CAN BUS decoding)
    The digital speedometer works without the use of OBD2, fuel, handbrake still nothing (these parameters will show rather only with OBD2 how to wash, straighten)
    The whole radio panel still dims after turning on the lights, ILL cable is not connected - it bothers me terribly because on a sunny day you can hardly see it, and at night it will be too light for me to change manually -
    Someone will tell you what to do with it? I would like the brightness to not change when I turn on the lights, in no menu do I have this option.
    Thanks
  • #3 18881838
    mirek301
    Help: 24
    Rate: 52
    Did you deal with the radio?
  • #4 18882225
    benekdp
    Rate: 26
    What do you need specifically?
  • #5 18889673
    mirek301
    Help: 24
    Rate: 52
    I had a similar one at Seat Altea but it was the fault of the can-bus module.
    I didn't know the counter for one from Seat Toledo full fis
    Now I have everything burning on the meter and on the radio, I can even read text messages from the telephone on the radio or in fis.
  • #6 18936857
    tomecki87
    And did you deal with this dimming of the backlight? I have the same, and it irritates me terribly on a sunny day. Also ILL have disconnected.
  • #7 19537885
    dzik9999
    Rate: 22
    How did you deal with connecting such a radio? did you use CAN H and L or K and L? Do you have any additional module for the radio? or directly to CAN H and L? and as with the settings on the radio. I have a Fabie 1 1.4 16V (06)
  • Fifth CAN-bus decoder restored missing radio functions
    #8 20513607
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3631
    mirek301 wrote:
    I had a similar problem in Seat Altea but it was the fault of the can-bus module.
    For me, only the fifth CAN-Bus decoder allowed the radio to fully "spread its wings". Interestingly, not intended in the specification for my car, and ordered without any hope of success only because it cost 4 € 🤪
    In previous decoders, the option of updating the software did not help - some functions were still missing or did not work properly.
  • #9 21412994
    rmedziak2
    [postid]18936857/postid] Mate, I had the same problem on my Xtron radio. There was no button illumination, but the cause was trivial. I connected the orange wire from the radio to the yellow wire from the power supply and everything is ok.
  • #10 21413619
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1412
    Archived topic - discussion has not taken place for over a year. Only add a reply if you have advice to add.
A user installed an Android 7.1 radio with a CAN-Bus module designed for VW vehicles in a 2008 Fabia 2. Post-installation issues included the instrument cluster display between the speedometer and tachometer not showing radio information, failure to detect reverse gear, and absence of parking sensor graphics. The display only showed limited data such as door status, mileage, and battery charge, with incorrect readings for handbrake status, fuel level, and speed. After connecting a reverse camera, the image appeared correctly when reversing, and parking sensor graphics displayed as expected. Hidden menus accessible via repeated taps on kernel and OS version allowed changing the CAN-Bus car model decoding. The digital speedometer functioned without OBD2, but fuel and handbrake status required OBD2 integration. The radio panel backlight dimmed after turning on vehicle lights, which was bothersome, and the ILL (illumination) wire was disconnected. Other users reported similar CAN-Bus module compatibility issues, with one resolving full functionality by using a fifth CAN-Bus decoder not originally specified for their car. Another user fixed button illumination by correctly wiring the radio's orange wire to the power supply's yellow wire. Questions arose about proper CAN wiring (CAN H and L or K and L) and the use of additional modules for full integration.
