Columbus RNS 510 Touchscreen Unresponsive - Seeking Schematic for Backlit Display Repair
rakato11 12714 12
How can I fix an RNS 510 touchscreen that has backlight but does not respond to touch?
The touchscreen fault is often linked to MPEG damage rather than the backlit display itself, and the suggested fix is to flash the memory or disable the MPEG module in setconfig, then upload the firmware with the update option disabled [#19499346] After that, the unit should start, and firmware menus can still be navigated with the buttons and confirmed without a working touch panel [#19499346] One reply also cautions that it is not necessarily a software problem [#18029491]
  • #1 16435335
    rakato11
    Rate: 15
    Hello everyone. The touch screen on the radio suddenly stopped working.
    Backlit display, but when you touch to select a function, it didn't respond.
    I am asking for help, I was looking for a schematic but did not find it. If anyone had, I'd be grateful.
  • #2 17349442
    farbafarba
    Hello, I would like to refresh the topic because I have the same problem after replacing the battery. The touch does not work and you can not enter the code, after reading many threads I came to the fact that it is the fault of the software and now the question is what soft can be uploaded to 3T0 035 680A on the housing I have SW 2724 and HW H41 of course Skoda Columbus.
  • #3 17360562
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    farbafarba wrote:
    Touch does not work and the code cannot be entered
    The radio can't see you.
    In his car, after disconnecting the battery, he does not ask for a code.
  • #4 17361031
    farbafarba
    Hello, the radio in my own car has not changed, only the new battery, the radio turned on after a while later after turning off the engine, the code cannot be entered. Connected on the table behaves the same, so the question what to do next?
    Adds a photo from the navigation version
    • Columbus RNS 510 Touchscreen Unresponsive - Seeking Schematic for Backlit Display Repair 20180801_161905.jpg (1.69 MB) You must be logged in to download this attachment.
  • #5 17361644
    tolo
    Help: 233
    Rate: 1178
    There was an overlay for the repair of the software, like no communication with CAN, look on the network.
  • #6 17362104
    farbafarba
    I understand, but now after the overlay I have only diagonal lines and I can possibly recover the skoda logo, only swl recovery is loaded, the rest I have an uprgrade error, so I ask which software to use? Okay, because maybe I did not express myself exactly, for a code without a car, I will deal with it later
  • #7 17382410
    farbafarba
    I still have a question, I read that the skoda navi have a lock on so that it is not possible to upload the older software, can it be somehow turned off when skipping typing from the panel?
    And something like this from the network:
    "Attention! Skoda owners
    Extract the PQTABLE and SKTABLE files from the image (use magiciso or ultraiso). The files can be found from the path: \ VUCI \ B101 \ RNSMIDEC \ PROG
    Rename the files by renaming only SKTABLE to PQTABLE and vice versa
    Replace the renamed files back with the image and save the image. Burn this image to a DVD or CD. Load or reload the firmware into the RNS-510 by following the steps below. "
    Need to always replace these files?
  • #8 17976581
    tottoro
    dyafarba did you manage the "non-touch" screen, because I have the same problem
  • #9 18028283
    farbafarba
    Hello, unfortunately I'm still without a solution, it's definitely the fault of the software but I don't know how to upload the whole thing and which, because it still crashes when uploading
  • #10 18029491
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    farbafarba wrote:
    it's definitely the software's fault
    Not necessarily.
  • Touch failure often caused by MPEG damage
    #11 19499346
  • #12 21809418
    michaeljamesromt
    I’ve seen this issue on RNS 510 units where the backlight works but the digitizer layer fails. It’s often a faulty touch panel ribbon, cracked digitizer, or controller IC, not the main display. Before hunting schematics, reseating connectors helps. Even fleets like Luxury Rides LLC run into similar head unit failures over time.
  • #13 21809510
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1409
    Archived topic from 2017 - and the discussion hasn't happened in about 5 years. Only add a reply if you have advice to add.
Discussion about a Skoda Columbus RNS 510 head unit with a backlit display but completely unresponsive touchscreen. The problem appears after battery replacement or power loss, with the unit sometimes not accepting the security code and behaving differently on bench power versus in-car. Several replies suggest the issue is likely software-related, possibly linked to CAN communication, firmware corruption, or MPEG module damage. Proposed recovery methods include firmware reflash, using update-disabled or setconfig-based procedures, and bypassing Skoda’s firmware lock by swapping PQTABLE and SKTABLE files in the update image. Later comments note that a non-working touch panel can also be caused by a faulty digitizer ribbon, cracked touchscreen layer, controller IC, or loose connectors, and recommend reseating connectors before searching for schematics.
