Foundation of RNS 510 + BT. - Postponed to B6 2007 RNS510 and bluetooth, coding.
dymek112 6804 2
  • Coding and wiring questions for RNS 510 Bluetooth retrofit
    #1 16580111
    dymek112
    Help: 5
    Rate: 12
    Hello everyone,
    Gentlemen and ladies, the matter is that the RNS 510 passat b6 2.0tdi station wagon from 2007 has been added to it, a 5N0 035 730 C Bluetooth module will be added to it. I'll describe the problems first.
    After installing this RNS in the car, the AUX changer sounds to me with bad quality, I hear hum, interference. It turned out there is an open fault in the AUX circuit. Is it necessary to swap some cables with each other or is it enough to check if everything connects well?
    There is also a coding bug in navki.
    Now the stairs begin.
    After adding the above mentioned bluetooth module, do I have to code something to make it work? I don't have VCDS but WOW Wurth 5.00.8r2 (Autocom / Delphi) and saw the encodings for Navi, Radio and phone there, but I did not see the encodings for CAN Gateway. Someone can help me with coding codes? Unfortunately wurth has no explanation, only a coding procedure. But will I not achieve anything without the CAN Gateway coding procedure?
    And the second question, I put the module under the seat, the microphone in the panel on the roof, and the antenna where?
    The navi cables for the module, for the antenna and for the microphone are enough or do you need to add something else?
    Coding view in Wurth.
  • #2 16582460
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    dymek112 wrote:
    AUX changer
    Is this a changer after all or AUX sounds bad?
  • #3 16582527
    dymek112
    Help: 5
    Rate: 12
    SZYMON BYDGOSZCZ wrote:
    dymek112 wrote:
    AUX changer
    changer
