Honda civic VIII - replacement of the direction indicator bulb
europlus20 28080 11
How do I replace the right turn-signal bulb in a Honda Civic VIII, and can it be done without removing the wheel or other parts?
You can replace it by accessing the lamp from the wheel-arch/bumper area, but the thread suggests there is no truly easy no-disassembly method. One reply says to lower the bumper, which takes about 15 minutes, then remove the lamp and change the bulb [#16441735] Another user says the manual lists the lighting-bulb replacement procedure on page 483 [#16443605] In practice, the instructions were said to be incomplete, and more than just the two clips may need to be undone; one user ended up tilting the wheel arch liner to get access [#16445395]
  • #1 16440646
    europlus20
    Rate: 83
    Hello, as in the topic I need instructions on replacing the right turn signal bulb (from the passenger) in the civic VIII or is there any way without removing the wheel, etc.?
  • #2 16441376
    Krzysiek0921
    Rate: 12
    For me in accordzie you have to take off the wheel arch and remove it half-blindly ... and the short light bulb is at least 2 hours for replacement ...
  • #3 16441584
    europlus20
    Rate: 83
    maybe it's easier to remove the whole lamp?
  • #4 16441653
  • #6 16441770
    europlus20
    Rate: 83
    I will look at the lamp for the markings and I will try to take a picture.
  • #7 16442640
    Krzysiek0921
    Rate: 12
    In my Hania the whole process of replacing the light bulb is in the instructions from the car.
    Do you have lenticular or ordinary light?
  • #8 16443258
    milejow
    Help: 1563
    Rate: 5149
    Have you ever seen the original lens there?
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #9 16443431
    Krzysiek0921
    Rate: 12
    Yes, I saw it because I have it myself.
  • Clarifying bulb type and checking the manual
    #10 16443590
    europlus20
    Rate: 83
    The lamps I have are ordinary, not lenticular, I was looking for some signs on the headlamp there are some numbers on the plastic and that's all, Are you telling me to look for a replacement description in the instructions?
    Moderated By CameR:
    Reg. 3.1.17. Do not send very basic questions that can be found in the user manual or generally available sources. Do not present the attitude that I am due. Take care of the level of questions and discussions. Thank you.
  • #11 16443605
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Replacement of vehicle lighting bulbs p. 483
    • Instrukcja obslugi Honda Civic VIII.pdf (8.83 MB) You must be logged in to download this attachment.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #12 16445395
    europlus20
    Rate: 83
    Ok, the bulb listed but the instructions in my opinion leave a lot to be desired, many more things need to be unscrewed than the 2 cuffs, at least for me it was to tilt the wheel arch.
The discussion revolves around the process of replacing the right turn signal bulb in a Honda Civic VIII. Users share various methods, including removing the wheel arch, pulling down the bumper, or removing the entire lamp for easier access. The complexity of the replacement process varies depending on the bulb manufacturer and type (lenticular vs. ordinary). Some users suggest consulting the vehicle's manual for specific instructions, while others note that the manual may not provide sufficient detail, requiring additional disassembly.
