Laguna III 2008 Grandtour - How do I change the direction indicator bulb?
dark21 17700 7
  • #1 16362376
    dark21
    How to replace the indicator light bulb in Laguna III?
    In the manual they write about the ASO, so it probably requires disassembly of the headlight and then probably the bumper.
    Someone will suggest?
  • #2 16364929
    genek1000
    Help: 289
    Rate: 1057
    Interesting topic because as I remember I have never exchanged the front indicator light bulb in LIII. From what I remember visually, this is rather not the case. :cry: But what ? Did you look under the hood? Is there a place to exchange? If there is no place, remove the headlight. How to remove the headlight is to remove the bumper because the screws are under the bumper. :cry:
  • #3 16365382
    dark21
    There is no place. I will still try to unscrew the wheel arch. If not, then it is really disassembly of the bumper and headlight.
  • Remove the bumper and headlight to access indicator bulb
    #4 16372025
    dark21
    I will answer it myself ;)
    Well, to get to the indicator light bulb you need to remove the headlight, but to do it you need to remove the bumper.
    This applies only to the direction bulbs, the others can be replaced normally.
    Contrary to appearances, this is not a very time-consuming activity.
    The bumper itself is on two bolts in the wheel arches, the rest are just latches. Reflector with 6 screws and after trouble.
    Thank you for your attention 8-)
  • Front bumper removal requires Torx screws and M6 bolts
    #5 16372109
    genek1000
    Help: 289
    Rate: 1057
    Or you did it when you were drunk :wink: or you don't have half front in your car :cry:
    To remove the bumper, you need to unscrew the front wheel arches from the bumper, i.e. 4 torx20 screws per side, two M6 screws (one per side) bumper from the body. Upper black bonnet lock cover - 4 torx20 screws from the top, 2 pins from the bottom of the cover and 3 catches. M6 screws from the bottom bumper plate to the front beam 3 pcs (or 5 - I don't remember much now)
  • Bumper and lamp fastener layout clarified with bolt counts
    #6 16372136
    dark21
    I wasn't drunk and the car is complete.
    I just didn't write everything that accurately. I believe that if someone undertakes such things, they can see what cover they have to unscrew.
    Once again I repeat: the bumper is on two bolts that are in the wheel arches, the rest are the same latches, and the lamp on six bolts.
    Well, but good: first we open the mask with the handle inside the cab on the left, right next to the clutch pedal ..... :P :-o
    there are no such, the same latches at the bottom
  • Correct bumper removal: wheel-arch bolts and latches
    #7 16372170
    genek1000
    Help: 289
    Rate: 1057
    You have unhooked the bottom bumper plate from the bumper - you've done some extra work. The bumper and plate as a dismantling element are one thing. You had to bend more under the car and unscrew the screws :|
  • #8 16372196
    dark21
    3 screws vs 6 latches, indeed, I made 2 hours of work :D
To replace the direction indicator bulb in a 2008 Laguna III Grandtour, it is necessary to remove the headlight, which requires disassembling the bumper. The process involves unscrewing bolts located in the wheel arches and removing several screws and latches. The bumper is secured by two bolts in the wheel arches and additional screws at the top and bottom. Once the bumper is removed, the headlight can be accessed to replace the bulb. This task, while seemingly complex, is manageable and not overly time-consuming.
