Honda Civic Ufo VIII: Troubleshooting VSA ABS System Check - Sensor Replacement & Clutch Impact
16827 1
  • Front left ABS sensor fault persists after replacement
    #1 16912220
  • #2 16913255
    piotrekwoj1
    Help: 947
    Rate: 3433
    The idea is that do a good diagnosis, not some flickering. Secondly, in the parameter sub-display, you can see if the sensor can see the rotation of the wheel. The Internet is not everything and a lot of "garażowców" writes nonsense. If you take the diagnosis, let me know, maybe we can do something.
