Dealing with Blown Fuses - L10A - Steps to Reconnect and Restore Power
boltron 5850 2
  • #1 16442874
    boltron
    Hello!
    I need help, traffic jams have just broken. I am sitting at the computer and suddenly a flash and the light went out in the living room and in the whole apartment nothing works.
    I unscrewed the middle plug, but it turned out from the plugs in the wall, the refrigerator does not work, etc.
    When I screwed it back in, it also didn't work. I pressed the red button in each traffic jam and then the black button at the end.
    I do not know what it is for, the fuse looks like this:
    http://www.ceneo.pl/2477841
    How to screw it in again, can I screw in some other?
    GOOD THEME TO CLOSE, JUST PUSH THE BLACK KEY, PLAYING MUSIC!
    wzielonymgaju18
    Help: 32
    Rate: 110
    To switch on the fuse, press the black button as far as it will go. (the plug must be screwed into the socket)
    But it may also be that the counter protection has worked.
  • #3 16442893
    boltron
    I'm closing, it's true that I figured it out myself, but thanks, I already thought that Friday would be over with matches. It's good that I didn't call the owner with such a trifle. Electric stores, on the other hand, are almost closed.
    One bulb did not work in the room.
