Samsung Galaxy S5 - After a hard reset, you can't log in to your Google acco
artur04c 6765 6
  • #1 16445236
    artur04c
    Rate: 97
    Hello, I have such a problem, well Samsung Galaxy S5 neo after a hard reset does not turn on. When trying to log in, a message pops up to log in to the previous account, although the phone was taken from the salon only logged in to one account and the password was not changed. In Google you can see this device and it is visible that it was turned on today, I logged into Google via PC without a problem and the phone crashes an error. I used many "patents" from youtube and via the OTB cable with the Bypass any Samsung Google Account Lock file, but after playing with the Bypass any Samsung Google Account Lock file is the same, i.e. an error and does not skip logging in. When it synchronizes with the database and then a message pops up saying that it is looking for an update, I turn off the router and the phone skips the login issue and returns to the second stage at the last stage :D over and over again. How to solve this problem? new soft? or what? Tel no longer has a warranty. Thanks in advance.
  • #2 16445672
    nutergsm
    Help: 1034
    Rate: 1665
    Go to the service where they will remove the frp blockade.
  • #3 16445700
    blade1231
    Help: 8
    Rate: 31
    Everyone who has a z3x box or similar is able to download this lock.
  • #4 16445774
    artur04c
    Rate: 97
    So installing the new software is pointless ??
  • #5 16445780
    nutergsm
    Help: 1034
    Rate: 1665
    Changing the firmware will do nothing.
  • #6 16446010
    artur04c
    Rate: 97
    Well, after the picnic I'll call the service, or give it back to the service because what Samsung has done with Google is a failure. So that you cannot log in to your own account, although if you log in using a PC, you can see that the phone is assigned to this account. Some failure.
    Moderated By nutergsm:
    We do not use vulgar words in any form in the forum. Please remember that. I have improved the post.
  • #7 16446192
    artur04c
    Rate: 97
    The phone works fine ;) "Samsung frp lock remove 2016 100% tested" helped me. I apologize for profanity, but I was carried away.
    PS. if someone had a similar problem and did as per the instructions, at the beginning I emphasize that to set the English language is much simpler ;)
The user is experiencing issues with a Samsung Galaxy S5 Neo after performing a hard reset, as the device prompts for a previous Google account login that they cannot access. Despite being able to log into the Google account via PC, the phone continues to crash with an error during the login process. Various methods, including using a Bypass file and changing router settings, have not resolved the issue. Responses suggest visiting a service center to remove the FRP (Factory Reset Protection) lock, as changing the firmware is deemed ineffective. One user successfully resolved a similar issue using a specific FRP lock removal method.
