Safe Removal of Kazama Tornado 348 Back Flap: Optimal Heating Time and Tools
131XIII 31047 10
How can I safely remove a glued-on smartphone back cover, how hot should I heat it, and what tools should I use?
Heat the back cover to about 90°C, ideally with a heater or a hair dryer, and start prying from the edge with a thin plastic tool such as a guitar pick or card [#16446849] There is no fixed heating time; heat in short bursts and check whether the adhesive starts to release, then slide something thin under the lifted area and keep working gradually [#16446884] One user reports opening similar phones with a dryer at maximum, limiting the airflow to the sides by placing the phone in a container, and lifting the back after about 1 minute when it is very hot [#16451578] Another cautions not to overheat the whole phone because of the battery inside; instead, heat one spot, lift slightly with a scalpel, and insert a plastic card to cut the tape [#16450512] The motherboard is unlikely to be damaged by this level of heating; the main concern is burning yourself while the phone is hot [#16446963]
  • #1 16446816
    131XIII
    Rate: 48
    Wanting to be a bit more embraced on the phones, I decided to start Kazama Tornado 348 for educational purposes
    And this is a phone that has a double-sided tape on the back cover, I took a hair dryer and a guitar bow. I blew this dryer a bit for 2-3 minutes and the glue did not move. I blew a little more, but the aluminum frame was already very warm and I stopped heating because I was afraid that I would damage the motherboard. The phone works fine. And now the question is, how much more or less do I need to heat the phone to be able to remove this flap and not be afraid that something will happen to the motherboard under the influence of temperature.
    Do I need a hot air soldering iron to do it with peace of mind?
    And do I need anything more than a guitar bow?
    How do you deal with removing the back flap?
    Thanks in advance for your answers ;)
  • #2 16446849
    micuszyn88
    Help: 5
    Rate: 47
    You need to heat up to about 90 degrees, best to do it with a heater, but a dryer will also do the trick :) it's best to start from the edge and gently pry it with something thin, for example with a guitar pick :) I did so. or something stiff but thin. When it starts to peel off, substitute something where it is already detached and continue to heat up. It is important not to rush and watch how the glue is released. I did it twice with the glass flap and it worked. I am sending greeting and I wish you good luck.
  • #3 16446872
    131XIII
    Rate: 48
    And heat it up for at least 5 minutes with a dryer? d
  • #4 16446884
    micuszyn88
    Help: 5
    Rate: 47
    Heat up and see from time to time if it starts to let go :) time is hard to tell :) I did it with a heater borrowed from a neighbor :) but I also watched if the glue was starting to release and I opened the flap, prying it open. :) If you only do flip removal tests, you have nothing to fear. If the operation is unnecessary, it is better to do it sensitively and carefully.
  • #5 16446895
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    Lead-free solder melts at about 230 degrees.
    If the dryer reached this temperature, it would burn your head ;)
  • #6 16446942
    131XIII
    Rate: 48
    Okay; d
    So I would have to try very hard to damage the motherboard with the temperature? ;)
  • #7 16446963
    micuszyn88
    Help: 5
    Rate: 47
    Sure. Just do not burn yourself when heating up because you need to heat up quite a bit.
  • #8 16450512
    blade1231
    Help: 8
    Rate: 31
    Glued phones with a battery inside, I do not recommend putting them on a heater. It is best to heat it up only at one point and not too much, and then with a scalpel (I use blades to remove the glue from under the polarizer), slightly lift the flap and insert the playing card into the slot. Once the card sits under the flap, we can easily cut the entire tape.
    In the new phones, everything is so folded that an ordinary wallpaper knife has a too thick blade, let alone a guitar pick.
  • #9 16451578
    jackq
    Rate: 26
    I opened them all with a dryer. It's just that I put the phone in a container to limit the air blow to the sides and then I drift with a dryer to the maximum - it is much more efficient and faster than on the table. After about 1 minute, when it is very hot, I lift the backs with a plastic in the shape of a guitar feather.
  • #10 16452307
    blade1231
    Help: 8
    Rate: 31
    Did you do galaxy s6, s7 ??
The discussion centers on the safe removal of the back flap of the Kazama Tornado 348, which is secured with double-sided tape. Users recommend heating the device to approximately 90 degrees Celsius using a hair dryer or a heater for optimal results. It is advised to start heating from the edges and to use thin tools like a guitar pick or a playing card to gently pry the flap open. Caution is emphasized to avoid overheating, as temperatures above 230 degrees Celsius could damage internal components. Some users suggest using a scalpel for precision in cutting the adhesive. Overall, patience and careful monitoring of the glue's release are key to a successful removal.
