Replacing Huawei P10 Lite Back Cover: Quick 706 Glue, Heat Settings, Tips & Mistakes
Gusto9 5730 4
  • #1 17124417
    Gusto9
    Hello. I wanted to replace the back cover on Huawei p10 lite. I warmed up with Quick 706 glue at the beginning setting the temperature to the lowest 100 degrees and tried even 150, I did not risk it anymore. After fisk associated with this method, I tried the dryer a good few minutes and unfortunately no effects. I am doing it for the first time and now the question is where is my mistake? On all YouTube tutorials, everything looks simple and here it is not. I will be grateful for any tips. Should I keep hot air longer? There were moments when it was impossible to touch the phone was so hot
  • #2 17125538
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Is your phone new or bought?
  • #3 17125628
    seba694637
    Help: 11
    Rate: 115
    Are you a service technician? Do you repair phones? It is a pity to overheat the batteries and burn yourself
  • #4 18633847
    Szymolek14
    Hello, I don't know anyone how to translate a finger reader from an old to a new flip
  • #5 18633893
    staś pytalski
    Help: 760
    Rate: 1436
    If you have removed the cover - heat it and push it out with your finger (push it out as if you had the cover on the phone). Just be careful because it's hot. The reader is stuck on strong double-sided adhesive tape.
