Effective Methods for Removing Aged Protective Foil from Metal Surfaces
maws 103972 12
How can I remove old factory protective foil from metal window sills or garage doors that has been left on for years?
Heat the foil gently with a heat gun or hair dryer, then peel it off in small pieces and clean the glue residue with extraction gasoline or denatured alcohol [#3390379][#3391877][#3397817][#3399589] If the foil is badly aged, cracked, or welded to the surface, use a scraper or a sharpened piece of plexiglass/polycarbonate to get under it and tear it off little by little [#3397817][#3392073] Do not use acetone or nitro solvent, because they can damage the varnish or the window sill material [#3391967][#3397817] One reply also notes that some installers use special liquids for removing this film [#3391967] In practice, the longer the foil has been exposed to sun/UV, the harder it becomes to remove cleanly [#3392077]
  • #1 3390250
    maws
    Rate: 16
    I have a request - does anyone know how to remove the factory-applied foil as a temporary protection for tin window sills, garage doors. I haven't removed this foil for a couple of years and now it's very difficult to remove it. Does anyone have any positive experiences with this?
    Regards
  • #2 3390379
    Qbuś
    Help: 380
    Rate: 876
    Electric heat gun, you need to slightly heat the foil and then it comes off, the remains of the glue that remains is (for me) denatured alcohol. :D :D :D
  • #4 3391906
    ^ToM^
    Help: 495
    Rate: 2939
    rather not really, I have such a very fine mesh and when it heats up, it comes off, between one mesh and the other, only a tiny piece.
    I wonder if anyone has practically solved the problem of removing this foil as it is already heavily cracked?
  • #5 3391967
    Orochimaru
    Help: 170
    Rate: 532
    Try different solvents. Nitro, acetone. Just check on an invisible piece to make sure the paint doesn't come off.
    Companies that assemble plastic windows have special liquids to remove this film.
  • #6 3392002
    Qbuś
    Help: 380
    Rate: 876
    I would try to stick the adhesive tape after heating it up and tear it off right away, try it, maybe it will come off in larger pieces :D
    happy!!!
  • #7 3392073
    dybas
    Help: 419
    Rate: 339
    It got me too. No chemistry helped, I tried alcohols,
    trichlorethylene, and solvents. It looked like foil underneath
    under the influence of time and the sun reacted with the material of the profile. I had to
    use scrapers. Unfortunately, it is known that the surface must have become dull.
    All in all, the effect is quite good, from a distance of several meters you can't see anything.
  • #8 3392077
    Leszek Andrzejczak
    Hello. You have a problem buddy. After a few years, under the influence of sunlight /ultraviolet/, the film became stiff, because the compounds that gave the film flexibility (softeners) "sweated". Removing it from large areas became very difficult. It is not possible to restore the film to its original properties. What remains is the fun of tearing off small pieces by undermining the foil with a piece of e.g. sharpened plexiglass or even better polycarbonate / e.g. They can be successfully sharpened to the shape of a knife on a regular grinder. ATTENTION !
    Do not use acetone or nitro solvent, which also contains a significant percentage of acetone /even up to 40%/. You can permanently damage the varnish or the material from which the window sill is made. For washing, use extraction naphtha, which dissolves the adhesive of the foil. You can put a cloth on the windowsill and moisten it with gasoline. It's cold and the gasoline won't evaporate too rapidly. After a few minutes, the film should be scraped off and the glue residue should be wiped off with a cloth dampened in gasoline. A lot of work, but it's the only way. And it should be remembered that the so-called The transport cover should be removed immediately after installing the window sill and making the so-called masonry treatments. Later, especially after a few years, we have a problem.
    Good luck and persistence.
  • #9 3397817
    ^ToM^
    Help: 495
    Rate: 2939
    Leszek Andrzejczak wrote:
    And it should be remembered that the so-called transport cover should be removed immediately after installing the window sill and making the so-called masonry treatments. Later, especially after a few years, we have a problem.
    You don't need a few years, for me after 6 months it was no longer possible to get off the 2 windowsills on the south side of the building.
  • #10 3399589
    unitral
    User under supervision
    Help: 85
    Rate: 175
    A hair dryer and extraction gasoline helped me :)
  • #11 20123024
    88wasylek
    Rate: 14
    I know this is an old topic, but maybe someone has already solved this problem thanks to this. On one of the tin windowsills the foil was not removed. At the moment it is a "spider web" with pieces of foil but so welded that there is no way to catch and pick even for a month. Maybe there is a safe way to do this? Anyone dealt with this?
  • #12 20123031
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1069
    Butter only real 80%. Seriously. The fat will dissolve the films. You have to wait a bit for an hour and rub it with a dishwasher.
  • #13 20331110
    pocztakarolbrzoska
    A hair dryer helped me. Great, thanks for the advice.
Effective methods for removing aged protective foil from metal surfaces, such as tin window sills and garage doors, include using heat sources like electric heat guns or hair dryers to soften the foil. Solvents such as extraction naphtha, gasoline, acetone, and nitro can help dissolve adhesive residues, but caution is advised to avoid damaging the underlying material. Some users recommend using adhesive tape to pull off larger pieces of foil. In cases where the foil has become brittle and cracked due to prolonged exposure to sunlight, scraping with a sharpened tool may be necessary. Alternative methods include using fats like butter to dissolve the film. Overall, patience and careful application of these techniques are essential for effective removal.
