LG 43UH6507 vs LF42652V vs 47LB730V vs 55LB650V vs 55UH6507: Comparing TV Models & Features
c-y-r-u-s 3117 17
Which of these LG TVs is the best choice for a good Full HD model with at least a 100Hz panel?
For your Full HD/100Hz requirement, the safest pick is one of the older IPS/120Hz models, especially the 55LB650V or 47LB730V; the UH6507 is 4K but only 50Hz [#16447542][#16447567][#16448767] The 47LB730V uses an IPS, 8-bit panel, but it is hard to find because it has not been produced for about 4 years [#16448767] The 55LB650V was the forum’s main recommendation because it is large, looks good on paper for IPS, and another user said it is very good in practice [#16447753][#16448129] If you sit about 2.5–3 m away, 55 inches is considered an appropriate size for Full HD [#16448493] The LF652 is also a decent older FHD TV with IPS and 120Hz, and one reply says the 47LB730V is above the LF652 rather than the same class [#16447567][#16447588]
  • #1 16447521
    c-y-r-u-s
    Help: 12
    Rate: 35
    As in the subject, I am asking for opinions whether the LG LF 42652v is a good TV or better
    LG 43UH6507 I can still buy it, but there is no 3D and I do not know what the matrix is or good, I mean the 43-inch version
    I am also interested in:
    -LG 47LB730V
    -LG 55LB650V
    -LG 55UH6507 vs LG 43UH6507
    Which will be the best
  • #3 16447546
    c-y-r-u-s
    Help: 12
    Rate: 35
    I seriously wonder about this -LG 47LB730V is it better than LF652v?
    4K I have no pressure, I just need a good FULLHD min 100Hz
  • #4 16447553
  • #5 16447558
    c-y-r-u-s
    Help: 12
    Rate: 35
    I do not buy used, it is about lb652v anyway ?? only for comparison. I mean the LG 47LB730V
  • #6 16447563
  • #7 16447567
    Ludwik XVI
    Help: 1325
    Rate: 788
    The LF652 was once quite a good FHD TV with IPS and 120Hz matrix.
    It had a very good price and was often sold as LG's top model in supermarkets like Auchan and Carrefour.
    LB650V is also IPS and 120Hz but I do not know this model. I think a model from 3 or 4 years ago ...
  • #8 16447574
    c-y-r-u-s
    Help: 12
    Rate: 35
    So lg 42lf652v and 47lb730v are the same ??
    -LG 47LB730V
    -LG 55LB650V
    -LG 49UF850V
    -LG 50LB670V
    In summary, which will be ok
  • #9 16447588
  • #10 16447624
    c-y-r-u-s
    Help: 12
    Rate: 35
    So, gentlemen, specialists who
    -LG 47LB730V
    -LG 55LB650V
    -LG 49UF850V
    -LG 50LB670V
  • #11 16447753
    Ludwik XVI
    Help: 1325
    Rate: 788
    My voice on 55LB650V, because it is the largest and quite ok on paper for IPS.
    The disadvantage is probably only the first version of the webos. You would have to check it out.
  • #12 16448129
    dodger156
    I also recommend the 55LB650V. A friend uses it and is very happy with it.
  • #13 16448341
    c-y-r-u-s
    Help: 12
    Rate: 35
    Other models
    -LG 47LB730V
    -LG 49UF850V
    -LG 50LB670V
    What matrices do they have? 55 inches is probably too much for a fullHD, what do you think?
    Model -LG 49UF850V is it full 4K?
    Added after 30 [minutes]:
    What matrix does this LG 47LB730V model have, I will probably take it
  • #14 16448493
    Ludwik XVI
    Help: 1325
    Rate: 788
    Perfect size for 2.5-3m distance
  • #15 16448598
    c-y-r-u-s
    Help: 12
    Rate: 35
    What matrix does this LG 47LB730V model have and where can I buy it? Or the rest?
  • #16 16448767
  • #17 16450752
    c-y-r-u-s
    Help: 12
    Rate: 35
    Someone just cleaned it up for me LG 47LB730V.
    I take -LG 47LB670V if it's a good choice for matrix 120Hz 2.1 sound
  • #18 16450915
The discussion revolves around comparing various LG TV models, specifically the LG LF42652V, LG 43UH6507, LG 47LB730V, LG 55LB650V, and LG 55UH6507. Users express concerns about the matrix specifications and refresh rates, noting that the LF652V features a 100Hz matrix while the UH6507 has a 50Hz refresh rate but supports 4K resolution. The LG 55LB650V is recommended for its size and IPS panel, although it has an older version of webOS. The LG 47LB730V is also discussed, with users inquiring about its matrix type and availability, confirming it has an IPS matrix and is difficult to find as it has not been produced for several years. Overall, the consensus leans towards the LG 55LB650V and LG 47LB730V as solid choices for Full HD viewing.
