Seeking 43-49 Smart TV with 100-120Hz Matrix, WIDI & PCMIA Card Slot Under PLN 2,800
czarnys69 5088 2
  • Clarifying 100–120 Hz TV requirements and budget
    #1 16660634
    czarnys69
    It's hard for me to find an answer anywhere or find conflicting information. I'm buying a new TV.
    I am asking for a proposal with a 100-120 Hz matrix.
    My requirements:
    - size 43-49 ",
    - WIDI,
    - good SMART (youtube, showmax etc., currently LG WEBOS 2.0, which works great),
    - YouTube support etc. from a smartphone
    - 100-120 Hz matrix,
    - space for a PCMIA card and antenna input (cable),
    - the best price is around PLN 2,300-2800
    Currently I used LG 42LF652V from which I was very happy when it comes to SMART functions etc. I was not happy with the image quality (the matrix was not evenly lit on a white background - darker lighter spots). I didn't report it, I only sell tv.
    I took into account Sony WD755 but apparently it has 50Hz matrix and LG UH6507 but once they write about 50Hz matrix and once about 120Hz. Philips PUS6561 met my expectations but my colleague has a similar model and the system hangs very much.
    Thank you in advance for your advice.
  • #2 16662390
    procsa
    Help: 173
    Rate: 364
    I recommend paying attention to the less popular TV producers in Europe, such as TCL or HISENSE, I personally bought a 58-inch hisense with 120 Hz VA 4K HDR matrix some time ago ... PLN 2,000! Matrix, the image is great, black is black etc., the sound is amazing, unfortunately a little worse with the software, a bit coarse menu etc., but smart TV is, YT works without a problem etc.
    Unfortunately, to buy a TV with a Samsung or Sony 120Hz matrix, you have to spend some money ... and similar, if not the same matrices, sit in much cheaper, less known TV producers.
  • #3 16662817
    czarnys69
    After searching, I find that it is very difficult to buy a TV with a 100-120Hz matrix and I will focus on those 50-60Hz. After all, 90% of these are on the market and nobody complains.
    Do you have any TV recommendable? I am thinking about LG UH6507.
    Added after 19 [hours] 19 [minutes]:
    Check-in: Nov 2015
    Edit Quote # 19 Today, 11:19
    implicitly
    I went shopping yesterday and I would rather choose between:
    - LG UH6507 (image smoothness ok, webos convincing me, good price, free magic remote control, on LG website and LG consultant says that 100Hz matrix, here on the forum write that 50Hz, in any case smoothness ok)
    - Samsung MU6102 (liquidity ok, in the store on the tested TV on a white background there was uneven backlight and it scares me off),
    - LG UJ635V (liquidity ok, newer model, the seller claimed that the 100Hz matrix, but I think it's not true)
    - Samsung MU6472 (recommended by the seller, price higher 600 PLN as above tv, I did not test, although the picture seemed ok at first glance)
    I rejected:
    Philips 6551 (the appearance of the TV and ambilight wins with everyone, 120 Hz, but the price is higher and I'm afraid of failure and software) how this TV falls with the model Philips 8109 ?? 8109 has a friend - image and ambilight great, however, the software is limping.
    Tcl, Thomson - falls out, I will not find out.
    Sony WE755 - nice, more expensive but the image fluidity was weaker as in the cheaper models
    Someone advise what to choose ?? I don't care so much about the 100Hz matrix. I found that 95% of the tv in this price range is 50 Hz and uses without any problems.
