Skoda fabia // Control arm pin - Replacing the pin or rod end
zxcdominik1205 5061 6
  • #1 16447761
    zxcdominik1205
    Rate: 18
    I am after replacing the steering gear. During the replacement, I heard from the mechanic that the pin needs to be replaced because it has play. I told him to replace. On receipt, he said that he had forgotten about it.
    When replacing the steering gear, the rocker pin is disassembled ?? Was it the end of the tie rod? I wanted to replace it after this pseudo-mechanic.
    I am asking because when asking how much it costs to replace the pin, he replied "already removed".
  • #3 16447788
    zxcdominik1205
    Rate: 18
    I explained a little wrong. They replaced the steering gear. They set the toe-in. During the exchange, he said that the pin was broken. But he did not name him. My question is did he mean the rocker arm pin?
  • #4 16447816
    bodek66
    Help: 13
    Rate: 14
    You wrote well, buddy: "pseudomechanic".
    Who in their right mind sets toe-in, since he previously found play in the suspension / steering. First, delete these clearances and only then set the toe-in.
  • #5 16447846
    zxcdominik1205
    Rate: 18
    I am just going to diagnose it. However, could he unscrew the rocker arm pin to replace the steering gear? Was it a pin built into the end of the tie rod?
  • #6 16448029
    grala1
    VAG group specialist
    Help: 1496
    Rate: 5054
    If you want to replace it, what's the problem? Unless someone else is to do so.
    Lift the wheel and you will see where you move where the play is.
    Kicked the tip but could feel there was play on the pin.
    Check on your own.
    Checking steering play with wheel movement and inspection stand
    #7 16449608
    g107r
    Help: 811
    Rate: 996
    Move the steering wheel gently, left-right, do not turn it hard, just move. The other person puts a hand on the steerer pin and tries to feel if there is any play. Knock, knock when starting the steering wheel, as well as changing the position of the tip to the switch? will inform you about the ease.
    Lift the wheel and grab the tire at the top and bottom, move as if you want to swing the wheel to the side, not turn - when turning, you can also feel the play in the steering tips.
    The third option is to go to the SKP, where I usually detect what and where is worn, broken, and this option could be the best, because with "one removal of the wheel" you will be able to replace the worn parts.
The discussion revolves around the replacement of a steering gear in a Skoda Fabia, specifically addressing concerns about a pin that may need replacement due to play. The mechanic initially indicated that the pin was broken but did not specify which pin, leading to confusion about whether it was the rocker arm pin or the tie rod end. Participants emphasize the importance of diagnosing play in the suspension and steering components before adjusting the toe-in. Suggestions include checking for play by moving the steering wheel and inspecting the components for wear. A recommendation is made to visit a specialized service for a thorough diagnosis and replacement of worn parts.
