Skoda Fabia I - Damaged Airflow Direction Blades in Air Vent: Repair or Replace?
MichalSG 7746 5
  • Clarifying whether damaged vent slats need replacement or reseating
    #1 16202352
    MichalSG
    Rate: 12
    Somehow, due to haste and inattention, my dad leaned against the air outlet by the passenger door and damaged two of the six airflow direction blades. The slats stick to one side of the airflow frame and the direction of their movement is opposite to the other ones. Have the slats popped out only from the hooks and it's just a matter of putting them in place, if it is a question of replacement, is the frame itself replaced or it is part of the board housing and you need to replace the entire upper cover of the dashboard :( ?
  • #2 16202454
    janek1815
    Help: 372
    Rate: 1062
    You yourself have to check whether they have broken or can be put back in their old place. I bet you can fix it. The entire grill can be removed by levering it.
  • #3 16217733
    MichalSG
    Rate: 12
    But will you not need to replace the entire grille or the top cover afterwards? I am not very experienced in this.
  • #4 16220381
    Jacek79
    Level 37  
    Help: 233
    Rate: 1132
    Buy on Allegro and by topic
  • #5 16220417
    Waldemar z Kaszub
    Help: 111
    Rate: 469
    It can also be glued with, for example, a droplet or similar. If you do well, there will be no trace. This is the cheapest and least labor-intensive option.
  • #6 16255106
    MichalSG
    Rate: 12
    By operating a normal key to the lock on the door, the slats have been placed in their old places and they all seem to rotate as they used to.
