Skoda Fabia 1.4mpi (2002) Hatchback - Power Steering Issues, No Electric Assistance
Lemonkush12 4191 2
  • #1 16665888
    Lemonkush12
    Hello, some time ago my problems with power steering started. At first the power steering did not work by turning the steering wheel only to the right, there were a few moments when it was still working;]
    Currently it has stopped working completely.
    I will add that the power steering indicator does not burn, the fuses are also ok ...
    Fabia 2002 1.4mpi hatchback
  • #2 16666073
    Doktorr
    Help: 287
    Rate: 1098
    Communication with the support module is? the condition of the plugs from the electrohydraulic power steering unit?
    The most common cause is water seeping inside the unit and killing the electronics.
  • #3 16666105
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    First check the fluid level in the pump.
    The most common fault is a rotting beam on the left stringer.
    If the fluid is connected to the computer, see if there is a reaction to turning the steering wheel in the measuring blocks and if there are any errors.
