Refrigerators 10 year compressor warranty - is it worth it or marketing? What do
anu1973 63870 18
What does a refrigerator’s 10-year compressor warranty actually cover, and is it worth buying if the problem is often a leak rather than a dead compressor?
Usually it covers only the compressor or inverter unit itself, not the whole sealed refrigeration system, so labour, diagnosis, travel and leak repairs are often excluded [#18065259][#16453762] In one Samsung case, the warranty paid for the inverter motor, but the customer still had to pay about 500 PLN for diagnosis, service travel and labour [#18065259] One LG report says that if the compressor fails, the customer does not pay for the repair and the related replacement parts/labour are covered, but it still depends on the service terms and an authorised repair path [#16767569] Another reply warns that compressor failure is relatively rare in fridges under 10 years old, while leaks in the sealed system are more common, so a compressor-only warranty may not help with the failure mode you are worried about [#16453802] There was also an older Whirlpool example where the warranty was broader and covered the refrigeration unit/system, but that appears to have been an older special case rather than a general current rule [#16453926] So the warranty is often more marketing than real protection unless the written terms explicitly include the sealed cooling circuit and all repair costs [#16453762][#18065259]
  • Whether compressor warranties cover leaks and service costs
    #1 16453746
    anu1973
    Rate: 9
    Some refrigerator manufacturers are tempted with a 10-year warranty on the compressor:
    Samsung, Whirlpool, LG.
    It seems that everyone above the first 24 months, applies the principle that they do not pay for the parts,
    but for commuting and labor, yes.
    The question is, what does the compressor warranty actually cover?
    I found a post from 2008 - that is, it is not known if the information is currently - that
    Whirlpool understood then the warranty on the compressor in a wide way. Someone had
    trouble with the fridge for over 2 years, but with this warranty of 10 years for a compressor. A leak was found
    and the system was filled twice (which cost PLN 2X300). Finally, it was found that the leak is in place
    for repair and the refrigerator has been replaced. The warranty for the compressor understood in this way would be very attractive, because from what I see, the problem of unsealing is quite common.
    A moment ago I called Whirlpool and the consultant said that the 10-year warranty is for the compressor itself.
    This is not the final information for me, because I got the impression that the girl just read the information available to everyone, was not very practical.
    Question No. 1
    Does any of the manufacturers offering a 10-year warranty on the compressor understand the entire refrigeration system as a compressor, including its unsealing?
    Question no. 2
    If it is a guarantee for the compressor itself, is it worth to be tempted, or is it rather a marketing gimmick?
    Ie. the compressor as such breaks down very rarely, and if it breaks down then the service fee for the company's service will be
    and so bigger than some local specialist?
  • Questioning what 10-year compressor warranties actually cover
    #2 16453762
    Piotr2608
    Help: 851
    Rate: 4487
    anu1973 wrote:
    Question No. 1
    River theme. Not 10 years and up to 10 years on selected models of refrigerators after all, the refrigerator must be expensive for the manufacturer to come out with the face and not with the debt after the service. In fact, we are cooked by this guarantee. With these 10 years warranty (depends on the manufacturer's and authorized sites' views) we can not interfere in repairing the device yourself, or by using local unauthorized services.
    I would not be so sure. Murphy's law is the most applicable.
    ZimTech Piotr Zimny
  • #3 16453802
    robokop
    Help: 1763
    Rate: 6371
    Only that the fallen compressor is a total rarity in refrigerators younger than 10 years - for this unsealed system is the norm. So this guarantee you can put on your shoes ...
  • Inverter electronics may fail before compressors, offsetting energy savings
    #4 16453915
    Piotr2608
    Help: 851
    Rate: 4487
    Yes, if we are talking about a normal old type compressor. The construction of a new inverter inverter is nothing else but a linear motor powered by inverter electronics. And here comes the so-called drink the water.
    Assuming that this linear motor will last 40 years, the electronics controlling it will not necessarily endure this 10 year period of work. The average price of the new module is about 350-520 PLN plus a replacement in this case by an authorized service, so an additional + 200PLN is added to the exchange.
    Secondly, the savings from using no (after any comfort) in unfavorable thermal conditions, such an "inverter" will work 24 / 24h, after all, it will have to maintain the temperature set in the refrigerator.
    Samsung RB37J5345 fridge - annual energy consumption 259 kWh (inverter)
    Samsung fridge BRB260076 - annual energy consumption of 240 kWh (classical)
    ZimTech Piotr Zimny
  • Compressor warranties may ambiguously cover refrigeration-system leaks
    #5 16453926
    anu1973
    Rate: 9
    Here, the mentioned posts - unfortunately, age-old, so it is not known whether the current - in which the warranty on the compressor = guarantee for leak tightness (or perhaps it was once specified specifically - a guarantee for the refrigeration system). In total, it is difficult to say what these guarantees cover, because in principle even the warranty for a compressor is not mentioned in the warranty, and the promise is a sticker on the refrigerator and, for example, in the case of Samsung, "the websites know which models they are covered by an extended warranty on the compressor ".
    https://www.elektroda.pl/rtvforum/topic508974.html
    https://www.elektroda.pl/rtvforum/topic892047.html
    https://www.elektroda.pl/rtvforum/topic720278.html
    And an old press release:
    "Whirlpool Polska is introducing a new extended 7-year warranty for the perforation of the equipment housing from July 1. All Whirlpool, Ignis and Bauknecht products purchased after July 1 will be covered by a higher warranty, at the same time a 7-year warranty for the refrigeration unit and the system will apply. refrigerators in refrigerators, freezers and fridge-freezers by Whirlpool, Ignis and Bauknecht. Whirlpool also gives a 7-year warranty on the engine and main tank for washing machines, washer-dryers and dryers of the above mentioned brands. (MK) "
  • #6 16453943
    Piotr2608
    Help: 851
    Rate: 4487
    The topics from the links relate to refrigerators with an ordinary compressor.
    The author of the topic is interested in the subject of refrigerators with an aggregate, a so-called compressor. inverter because currently only a 10-year warranty is given for such.
    Whirlpool - you can see that Americans want to conquer Europe ;)
    ZimTech Piotr Zimny
  • Asking whether compressor warranties include system tightness
    #7 16453957
    anu1973
    Rate: 9
    Perhaps I have mixed up too much and I am referring to a guarantee that has long gone to the archive.
    In total, I did not even know that the aggregate and compressor is something else - I used these replaceable names.
    I'm totally indifferent to what's going on inside, I'm most interested in whether or not anyone now offers an extended one
    a guarantee for the entire refrigeration system. Searching for the fact that once there was a guarantee for an aggregate and refrigeration system, it can
    currently, a long warranty on the compressor also includes the refrigeration system (its tightness).
  • Clarifying inverter compressor terminology and reliability concerns
    #8 16454153
    robokop
    Help: 1763
    Rate: 6371
    I wonder what for yntelygent he understood these terms - an inverter, linear or linear compressor. None of these terms is true - there is neither a linear engine https://pl.wikipedia.org/wiki/Silnik_liniowy, nor linear - because such a verbal freak does not occur in nature, nor inverter - because what is there reversed? Ot eccentric / spiral compressor, called the English "scroll" driven by an asynchronous motor through the inverter - with variable speed, thus achieving higher efficiency, compared to the classic reciprocating compressor. There is a very unreliable and unstable electronics of the inverter - any surge voltage, atmospheric discharge, sparking loose contact or ubiquitous moisture are able to "toto". For more than half a century, refrigeration appliances for general use have been manufactured with traditional piston compressors, controlled on / off - as you can see everything can be fought in the name of progress.
  • Inverter compressor may use more total electricity despite EU ratings
    #9 16454168
    Piotr2608
    Help: 851
    Rate: 4487
    robokop wrote:
    as you can see, everything can be fought in the name of progress
    ... and you can, of course, make progress in the name of progress. Electricity consumes more than a refrigerator with a classic compressor. As I talked to a gentleman who in the institute is involved in the testing of such inventions, he said that the graph and the straight line for the EU counts, after all it uses less electricity than a classical compressor at a given moment. Total at a given time, such inverter chimera will use more power, but the graph is a graph.
    ZimTech Piotr Zimny
  • Traditional compressor may be more reliable than linear models
    #10 16460899
    karolb863
    I am reading this topic because I am just looking to buy a fridge, I would like a Side by Side fridge with an icemaker, I was wondering between Samsung and LG, just because of the "linear compressor" (10 years warranty), but reading the posts here I come to the conclusion that maybe a better choice will be a traditional compressor (less failure of control with this compressor), I really do not care about the great energy savings, which is not necessarily true - as shown here.
  • #11 16461043
    robokop
    Help: 1763
    Rate: 6371
    Referring to the post above, I would probably choose LG myself. Maybe Samsung is and more modern / prestigious, but definitely in my opinion LG has more advantages - even the service.
  • LG and Samsung considered qualitatively similar, with Samsung marketing concerns
    #12 16461688
    karolb863
    I was in the shop today, not so much idiots and you're a salesman - he was probably quite objective, not necessarily recommending Samsung, though he also claimed that maybe it is more popular, but not necessarily better than LG, said that they are qualitatively similar, and Samsung tempts you not quite needed gadgets and quite heavily marketing (I compared it to Castrol in the automotive industry).
    now I am more inclined towards LG, although I do not know why, I have another month to think about it, in addition to the fridge, I still have to buy a dishwasher, a washing machine and an extract.
    Buying home appliances is not as easy as it seemed :)
  • LG covers compressor replacement labor and related parts
    #13 16767569
    lysyarnold
    Rate: 34
    I do not know how repetitive it is but I got the information that in LG if the compressor is being blown out, the customer does not pay for repair. That is, labor and parts connected with exchanging the compressor (driers, coolers etc.) are on the LG side. That's how my brother-in-law was treated when he broke the fridge. I wonder if someone else had such an ailment - because it's a few in my pocket. Only they pinched that the unauthorized service should not leak the system - it's about ensuring that nothing else is damaged.
  • 10-year warranty excludes labor and transport costs
    #14 18065259
    Andrzej_Wrocław
    I just got the inverter in a 4-year-old Samsung refrigerator. Because it was covered by a 10-year warranty, so I calmly called the site and here the first zonk - the warranty covers the inverter, but for commuting and labor related to the exchange I have to pay about 500 PLN. Well, it's hard, a bit of bitterness, but what to do, I agreed and here the second zonk - repair only in a month (sic!). Nothing helped with the translation, that they are going hot, that I need a refrigerator, that my wife will throw me out of the house - the lady was adamant - FOR THE MONTH. I decided to buy a new fridge, definitely not SAMSUNG!
  • #15 18065357
    lysyarnold
    Rate: 34
    Buy yourself a LG. They are linear compressors and the warranty is full. If the compressor fails, you do not pay anything. At least it is in K Rakow.
  • #16 18067112
    Andrzej_Wrocław
    I checked and I did, thank you for the advice.
  • #17 18220259
    zett1
    Rate: 48
    Again these "linear compressors" ;) ) I suspect that it will stay like that, just like a led bulb or halogen LED.
    A few days ago, choosing between Samsung and LG I bought ... Amica, since yesterday it has been cooling. Similarly, Samsung has been the owner of the "fridge part" of Amici for several years. In any case, the new Amica replaced the old Amica, which served faithfully 15 years, until some refrigerant escaped and the freezer seals began to look bad ....
    [quote:c90b7ef125="robokop"] I wonder what yntelygent thought of these terms - an inverter compressor (... ;) None of these terms are true (... ;) or inverter - because what is inverted there? (... ;) driven by an asynchronous motor through an inverter
    I suspect that this inverter came from: inverter. Inverter - from English power inverter.
  • Samsung warranty covers only compressor parts
    #18 21515529
    tobililstar
    Many years old this thread is but I have just been confronted with a freezer failure (refrigerator works) on my Samsung fridge and I can tell you about the Samsung warranty on the inverter motor. Here's the response from Samsung when asked if it's normal for them to call out ridiculous money to replace a warranty item.
    "The repair must be carried out by an authorised service centre. The customer covers the cost of the diagnosis, the replacement of the motor and the service travel. The warranty covers the cost of the parts, in this case the motor."
    Also, door slamming 150 PLN, diagnosis 250 PLN, engine free and labour cost 1700 PLN parts :P .
    Someone asked if this made sense. My fridge FAILED 5 MONTHS after the warranty. And it was not some cheapest model.... Anyway, the total cost is almost half a new fridge.
    It's a drama, and what pisses me off the most is that they are bragging about what kind of promo they are giving.... 10 years. In the shop they necessarily repeat it. And in fact it's a joke. I don't know what it's like with other manufacturers, maybe it's similar. In our country, the public is allowed to be treated in this way, so I grit my teeth. Apparently they are acting in accordance with the law. I leave information for others, because I have the impression that not many people are aware of this. Another thing is that Samsung which seemed to me to be a quality company is just a rag, a sh*t. I am rather done with them and I don't just mean AGD. pzdr
  • #19 21515543
    Piotr2608
    Help: 851
    Rate: 4487
    tobililstar wrote:
    Also, door slamming 150PLN, diagnosis 250PLN, engine for free and labour cost 1700PLN + parts
    After all, I always say it - a pic of water, the same with the extended warranty....
    ... ... but to rip off a naive customer - priceless :)
    ZimTech Piotr Zimny
  • Topic summary
    The discussion addresses the value and scope of 10-year compressor warranties offered by refrigerator manufacturers such as Samsung, Whirlpool, and LG. It highlights that these warranties often cover only the compressor parts, while labor and service fees remain the customer's responsibility. The warranty typically excludes unauthorized repairs and self-servicing, limiting coverage to authorized service centers. Users report that compressor failures within 10 years are rare, but leaks in the refrigeration system are more common and not always covered. The term "linear compressor" used by brands like LG refers to inverter-driven scroll compressors with variable speed control, which may have more complex electronics prone to failure compared to traditional piston compressors. Some users note that LG offers more comprehensive warranty coverage on compressor repairs, including parts and labor, while Samsung's warranty often requires payment for labor and service travel despite covering parts. Repair delays and high service costs under warranty are also reported, leading some to prefer traditional compressors or alternative brands like Amica. Energy consumption comparisons between inverter and classic compressors show mixed results, with inverter models sometimes consuming more power overall despite lower peak usage. The discussion underscores the importance of understanding warranty terms, the distinction between compressor and refrigeration system coverage, and the trade-offs between compressor technologies when purchasing refrigerators.
