Samsung RB31FERNCSA - refrigerator loud compressor operation - digital inverter
majkwro 17490 5
  • #1 16229283
    majkwro
    I bought a refrigerator from the topic and unfortunately I got a copy with a loud compressor. Of course, according to Samsung, everything ok. At PW I can send youtube link to a similar sound. Is it possible to do something about it? Somehow mute / soundproof. The refrigerator behind it has walls on the sides of the kitchen furniture, but it covers an eye 1/3 of the refrigerator (depth). Preserved min. 5 cm distance on each side.
    I am asking for some help. greetings
  • #2 16229976
    Piotr2608
    Help: 851
    Rate: 4487
    You will not do anything about it, you can try to replace the fridge with one that does not make noise. In the past, the inverter compressor was covered by a 10-year manufacturer's warranty.
    majkwro wrote:
    I bought a fridge from the subject
    This is a new fridge, do I understand?
    ZimTech Piotr Zimny
  • #3 16230077
    majkwro
    Nowa, has more than 2 weeks. Can not be damped in any way, those mats that are under and around?
    EDIT: I understand that I can not cover this "open back" at the bottom where is the compressor? Fridge supposedly gives away the heat sideways ....
  • #4 16283750
    loppo
    Paste the link with sound as it works or record a video.
  • #5 16345399
    Franki67
    Rate: 8
    If you still have this problem with the fridge, write what exactly is wrong, I have a rather similar one, RB31FERNBSS, the three letters at the end of the model are different, mine is No Frost, it was loud, I was going to advertise it too, but I worked it out myself, and I am already sleeping peacefully, and sometimes I got up at night and quieted me down, so tarabaniło.
    Item
    Edit:
    However, I will describe the repair of a noisy refrigerator. After unscrewing the back cover, we can see the compressor, on the top of the compressor there is a white condensate container, from which the water collected there evaporates, and it was he who was the cause of this mess, once it was slightly unscrewed. However, there is an invisible screw in its center, you can track it with your finger, because you can't really see it, you need a very short cuff to spin it, but to do.
    However, all this is not enough, because it was not quite quiet yet, so I stuck a sponge on this white container, two long strips of sponge along the container, one on top of the other, so two, because one was too thin, should be thick enough to tighten the sponge. aluminum cover, it pressed lightly against this sponge, and thus muffled the white container. I used a centimeter sponge with glue already applied, two strips, i.e. about 2 cm in total, use this sponge by roofers to seal sheet metal on the roof, but whoever has what is at hand will use it, but this sponge is perfect.
    If someone did not understand, please write or even give the phone number, I will call you and I will try to help. I decided to write about it because it was driving me crazy, even at night I would get up and silence her. I figured maybe there are people who can't sleep because of that. If I helped, click that I helped.
    Item
  • #6 18983723
    Mario1470
    Hello. Is there anyone else here who can help me with the loud work of the compressor in the Swmsung glaciers model: RB29FWRNDBC? Made in Poland ? I have recorded a film and I would like to know what can I do with it?
    Well, I can't send the video, nue know why?
    I will describe my problem.
    When the refrigerator starts to cool down, the compressor starts to run and a buzzing sound is activated. It does not last the entire time the compressor is running. After a while, the buzzing disappears and the compressor works perfectly.
    Tomorrow he will try the trick with the screw in the center of the white water container ?
    I will certainly write again. I will also try to work on the movie.
    Thank you and best regards.
