[Solved] Electrolux EWT1266TLW Top-Loading Washing Machine: Is It Worth Buying for 700 PLN?
paulex80 10689 9
Is it worth buying a 2-year-old Electrolux EWT1266TLW top-loading washing machine for 700 PLN?
No, it is probably not worth buying it for 700 PLN. One reply says you can get a new washing machine with a 2-year warranty for not much more, and once the Electrolux is out of warranty any failure makes it a poor deal [#16461800] The same reply warns that replacing the control module can cost around 700 PLN, which would make the repair uneconomical [#16461800] Another reply adds that spending 700 PLN on a used machine is pointless if you can buy a new one for about 1000 PLN [#16462058] If you choose new, one answer suggests Electrolux or Bosch and says Whirlpool is not a good choice [#16461984]
  • #1 16461681
    paulex80
    Rate: 27
    Hello, I have to buy a top-loading washing machine this time, it doesn't have to be new, it would be good to be able to repair it cheaply in the event that the washing machine will not be used very often. I will be very grateful for the suggestions.
    Is it worth buying Electrolux EWT1266TLW 2 years for 700 PLN?
  • Avoid out-of-warranty Electrolux due to module costs
    #2 16461800
    r103
    Level 37  
    Help: 283
    Rate: 968
    Not really - you won't get much more expensive with a new one with a 2 year warranty. It is already after the warranty and it is a modern washing machine and if you break it, e.g. replacing the famous "control module" for which the manufacturer set the price to e.g. PLN 700 will be unprofitable ...
    If I were to take a stimulant, I would like Miele for 700 zlotys, maybe the same as this Electrolux, but at least you will know how a heavy weight washing machine works :-)
  • Request for Whirlpool and new washing machine recommendations
    #3 16461827
    paulex80
    Rate: 27
    Well, I will try it once and I will not want other washing machines :-D and what do you think about this machine https://photos.google.com/share/AF1QipMUC9nmF...?key=VTJzNzJqUzcyU2R6WHAxTlNfTnhyNjdiNzEzQkdn
    And what new do you recommend, can Whirlpoole be?
  • #4 16461984
    hessto
    Help: 10
    Rate: 79
    loaded from the top of the door
    E.g. Normal powder or (left right slider) liquid for powder, rinsing liquid ...
    Electrolux is good ... also Bosch ...
    Whirlpool is bad.
  • #5 16461994
    paulex80
    Rate: 27
    what would you advise specifically, because used is a risk of blinding, I will give less, but later I will clutter for e.g. the control module or something and why whirpool falls off, what is wrong with him?
  • #6 16462058
    r103
    Level 37  
    Help: 283
    Rate: 968
    The Trurl Post Writing Machine / I call it hessa because of the rather original syntax / - it quite sensibly noticed the powder / liquid container - that in AEG / ELECTROLUX it is not in the door as in all other top-loading washing machines / of course except also Miele / only in the washing machine body - a very elegant and practical solution.
    Maybe once again about used - if someone gives you for free because he doesn't need it or for the proverbial bottle, then spend 700 PLN is pointless to buy a new one for 1000.
  • #7 16462095
    paulex80
    Rate: 27
    r103 wrote:
    in other cases spending 700 PLN is pointless to buy a new one for 1000.
    100% consent from new to max. PLN 1000 is what to buy?
  • #8 16462477
    r103
    Level 37  
    Help: 283
    Rate: 968
    http://www.ceneo.pl/Pralki/Ladowanie :O d_gory; search-washing; M750; N1000; 0112-0.htm
    And here the draw is probably left because they are all roughly the same, aaa is also Electrolux from the advice of Trurla Machines ...
  • #9 16463349
    paulex80
    Rate: 27
    I don't know if it's the best choice, but I decided to do it
    Electrolux EWT11064IKW for 1000 PLN with a 24-month manufacturer's warranty, the price is reduced, due to the light upholstery of the corner of the washing machine.
  • #10 17157900
    paulex80
    Rate: 27
    I bought Electrolux.
The discussion revolves around the Electrolux EWT1266TLW top-loading washing machine, which is being considered for purchase at 700 PLN. Users express concerns about the machine's age, potential repair costs, and the value of investing in a used appliance. Recommendations lean towards opting for a new machine with a warranty, suggesting that for a similar price, one could acquire a new model with better reliability. Brands like Miele and Bosch are mentioned favorably, while Whirlpool is criticized for its performance. The conversation highlights the importance of warranty and repairability in choosing a washing machine.
