Hello ! I have a Mercedes in 203 from 2001 elegant version 2.2 CDI, after diagnosis SD error P2200 - the automatic transmission works only in 1st gear. Changed oil, filter, seals and plug, cleaning the control board did not help, that is, following the diagnostician's advice, replacing the transmission control board. Well, now the bothering problem that I buy in my Mercedes is A1402700561 can I use a replacement and do I need to program it? I found a replacement for FEBI 32342 supposedly to fit in the store so they said. I ask for advice.
Maniol81
Maniol81
