Mercedes e220 cdi W211 - Master cylinder SBC Sensotronic error c2359
london2004 11601 6
  • #1 16559646
    london2004
    Level 19  
    Rate: 392
    Master cylinder SBC Sensotronic error C2359. The Star Diagnosis service tester says that it is necessary to replace the entire component. After entering this error in google, no info. How is the problem?
  • #2 16559650
    damdam
    Help: 274
    Rate: 950
    If you have access to SD in the Developer version, you can do it. I can send you tips.
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #3 16559714
    london2004
    Level 19  
    Rate: 392
    I am asking for tips !! I have SD developer.
  • #4 16570391
    Józef18
    Level 32  
    Help: 168
    Rate: 165
    damdam - I also have a similar problem as the author can you send me tips?
  • #5 17211961
    london2004
    Level 19  
    Rate: 392
    Hello, can you do something with the error C235C? Star Diag says - replace pompe.
  • #6 17212250
    harlejowiec
    Help: 53
    Rate: 105
    In these pumps there is a bubble called a pressure accumulator. It is the same as the expansion tank in systems such as installations which has probably lost pre-pressure. Just out of curiosity, I will ask if anyone changed it. I used to have a car like this with this type of service and I know it's a problem. Does the electric motor of the pump start every time the brake pedal is pressed?
  • #7 18750526
    london2004
    Level 19  
    Rate: 392
    C2359 does not want to erase. When entering the parameter as in the photo, feedback - lifetime has been reached.
    • Mercedes e220 cdi W211 - Master cylinder SBC Sensotronic error c2359 206B332D-4CFB-4843-A419-E7F15FFD9C0E.jpeg (1.47 MB) You must be logged in to download this attachment.
The discussion revolves around the C2359 error related to the SBC (Sensotronic Brake Control) master cylinder in a Mercedes E220 CDI W211. Users report that the Star Diagnosis service tester indicates the need for complete component replacement. Some participants inquire about troubleshooting tips and share experiences with similar issues, including the potential failure of the pressure accumulator within the pump system. There are mentions of difficulties in erasing the error code and concerns about the electric motor's operation when the brake pedal is pressed.
