Mercedes ML W164 320 DCI 2006: Automatic Gearbox Failure, Gears Lost After Few Kilometers
w124.300d 11256 7
  • #1 17087713
    w124.300d
    hello i have a mercedes w164 320 dci from year 2006 '. I have a problem with the automatic gearbox, namely - after plugging in the computer, you can not see any fault in the gearbox. when I start the engine, I put the gear forward, I will drive a few kilometers and the gearbox loses gears! When after some time, when the engine cools down, I start the engine, I engage the gear - I drive a few kilometers and the gears turn off again, please kindly help. thank you
  • #2 17088527
    zaxdamian
    Help: 14
    Rate: 67
    When was the oil changed? Is the oil level correct?
  • #3 17088727
    w124.300d
    the oil was changed and the oil filter 1000km. ago.
  • #5 17090367
    w124.300d
    thank you for the hint, I understand that your converter is damaged ????
    Added after 4 [minutes]:
    only that no. 658 in the diagram is this a bearing with washers ???
  • #6 17090596
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    Mercedes ML W164 320 DCI 2006: Automatic Gearbox Failure, Gears Lost After Few Kilometers It is a freewheel clutch (or brake).
  • #7 17098736
    w124.300d
    thank you, is it enough to replace the bearing ??? where can i buy them ??? How much does it cost ? respect for knowledge :)
  • #8 17102808
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    You can buy them at Midparts W-wa, price approx. PLN 200. First, check whether it is really damaged.
The discussion revolves around a 2006 Mercedes ML W164 320 DCI experiencing automatic gearbox failure, where the vehicle loses gears after driving a few kilometers. Initial diagnostics showed no faults detected by the computer. The user confirmed that the oil and filter were changed recently. Responses suggest checking the one-way clutch (freewheel clutch) as a potential issue, with a recommendation to verify if it is damaged. The user inquired about the replacement of the bearing associated with the clutch and where to purchase it, receiving guidance on a local supplier and estimated costs.
