Connecting TV BOX MXQ PRO S905x Android 6.0 64BIT SMART 4K to TV with HDMI Sound Issues
Scrufy 11451 4
  • #1 16470690
    Scrufy
    I have a question
    I purchased a TV BOX MXQ PRO S905x Android 6.0 64BIT SMART 4K in which the outputs look like this
    and I wanted to connect it with the tv which outputs look like this Connecting TV BOX MXQ PRO S905x Android 6.0 64BIT SMART 4K to TV with HDMI Sound Issues
    I am talking about ext6
    The picture works after hdmi but it has no sound and I do not know how to make it work.
    Thank you in advance for your help :) )
  • #2 16471891
    Polon_us
    Help: 1184
    Rate: 1280
    And the TV model? Are we to foretell?
    The colleague checked in the settings of this box that the sound is directed to HDMI?
    If the friend connects the case to the EXT7 TV, does it also have no sound?
  • #3 16473004
    Scrufy
    TV to Sharp LC 32D 44E BK
    As I connect to EXT7, it all blows in nicely only where there is a cable connected from the decoder.
    I also wanted to connect this TV BOX under EXT6 and how to connect it with HDMI cable it is only a picture and there is no sound.
    Any ideas???
    Polon_us
    Help: 1184
    Rate: 1280
    Scrufy wrote:
    As I connect to EXT7, it all flashes nicely
    Scrufy wrote:
    Any ideas???
    And from the first sentence quoted, the colleague did not draw any conclusions - compared to EXT6?
    Heh, I will skip this without any comment ...
    The instructions would be enough to review.
    Podpowiem - you should look at the "HDMI setup" menu ...
  • #5 16477903
    Scrufy
    Thank you :) )))
