TV BOX MXQ PRO S905x: USB WiFi Adapter Compatibility & Supported Models
6156 7
  • #1 16563269
  • #2 16563430
    LeDy
    Help: 1990
    Rate: 2937
    Of course. Wireless connectivity:
    Wi-Fi 802.11 b / g / n 2.4GHz
  • #3 16568110
  • #4 16568483
    mi-cha-el
    Help: 8
    Rate: 18
    What is the purpose of the external wifi adapter in this original tvbox is not working?
    I know from experience that there may be a problem with running the external adapter due to the lack of drivers on Android. It is true that there are more and more modified versions of the software for all Android devices that expand the range of possibilities, but there is a long way to make it as easy as in Windows, i.e. plug & play.
  • #5 16568784
    LeDy
    Help: 1990
    Rate: 2937
    W03 is suitable. Since it has in the parameters it means that it receives and not writing about the drivers.
  • #6 16571140
    mi-cha-el
    Help: 8
    Rate: 18
    I do not know if I do not understand the question or colleague LeDy, the author of the topic asks whether connecting the usb wifi adapter to the usb port of the device which is TV BOX MXQ PRO S905x working on Android will allow establishing wifi communication e.g. with a router or other access point, I replied that there may be a problem with running the external adapter due to the lack of drivers on Android.
    I have this TV BOX and I tried to connect various devices under usb and for sure the card e.g. with TPLINK and TL-WN722N does not work, neither do USB bluetooth adapters (I connected 2 different ones), but interestingly a webcam works how the house has not worked with any other device on Android so far (tablets, phones), the case of hubs looks similar, it turns out that manufacturers deliberately block the possibility of their use in order not to overload the usb port in e.g. the tablet. It looks like you have to approach each device individually to which external peripherals are connected, because in some things something works and in others it doesn't.
  • #8 16572955
    mi-cha-el
    Help: 8
    Rate: 18
    Buddy roko00, you can answer why these combinations since this TV box has a built-in wifi card and Ethernet (LAN)? What is the purpose of the additional wifi card connected to USB. The only thing that comes to my mind is that the internal card is damaged and a colleague is looking for another way to connect to the network.
    For me, the card given in the link is nothing more than connecting the hub with a usb-lan adapter, which still adds nothing to the topic because we still do not have drivers implemented in the main device which is TV Box, i.e. the card still connected will not work, another issue is also whether the hub itself will work (that is, if we "get" an additional 2 USB ports after connecting it), or will the situation I mentioned in the post above that this possibility can be blocked by the manufacturer.
The discussion centers around the compatibility of USB WiFi adapters with the TV Box MXQ PRO S905x. Users confirm that while the TV Box has built-in WiFi capabilities, external USB WiFi adapters can be connected, but their functionality may be limited due to driver support issues on Android. Some users report that specific adapters, like the TP-Link TL-WN722N, do not work, while other USB devices, such as webcams, function correctly. The conversation highlights the need for compatible drivers for successful operation of external adapters and the potential for manufacturers to restrict USB port usage to prevent overload.
