Renault Modus - central locking, the door does not open from the outside
tsz_79 11934 3
  • #1 16475886
    tsz_79
    Hello. Maybe someone will tell me. In the handle of the driver's front door a round bolt fell out, which made it impossible to open the door from the outside. I added the bolt, mounted it, and now the door opens, closes, etc. The problem appears when I click the central lock. to open. I have to open the door from the inside. Has anyone had a similar problem?
  • #2 16476033
    kamiloskop
    Help: 42
    Rate: 279
    Maybe your conversion doesn't do the job or something isn't folded there. Remove the bacon and take the test so that you can see everything well.
  • #3 16476136
    tsz_79
    It really is a banality that pin. There is not much there to fold. Someone can tell you how to remove all this lock in a modus?
  • Passenger door lock likely needs actuator inspection
    #4 16539781
    jajuger
    Modus 2008.
    I have a similar problem. The central locking does not open the passenger door. Car freshly bought.
    Test performed:
    with the door ajar, the lock is closed (with a screwdriver). With the remote control closed and open the door. Passenger's lock not open. Wines somewhere in the elements of the central lock. You will need to remove the upholstery. I found a manual for CLIO 3 (probably the same)
    https://www.youtube.com/watch?v=O83yZlkHIPY
    Car replacing the air condenser. When he comes back - I'll try.
    If anyone has any idea ....
