Renault Modus Double Tailgate Issue: Opening Small Hatch Affects Large Flap Functionality
zagtom 9105 5
  • Small hatch opening disables large hatch until diagnostic reset
    #1 16330012
    zagtom
    Help: 6
    Rate: 28
    Hello. Modus version with double tailgate. The main hatch works without problems until I press one (any) of the two buttons to open the small hatch. Closing and opening from the remote does not help, only after connecting the computer you can control the opening of the large flap (my equipment does not support the small one). And the big one will work fine again until it tries to open. little. Anyone had a similar problem? Or maybe someone has a diagram? I can't find anywhere.
  • #2 16330097
    kamiloskop
    Help: 42
    Rate: 279
    Check the lapel bundle at the beginning and then on the bsi cable.
    Tailgate interlock depends on shared lock microswitch signals
    #3 16330541
    genek1000
    Help: 289
    Rate: 1057
    The topic is probably more complicated due to the high popularity of the model, especially with an additional flap :D
    The first question is whether this copy had such a flap or was it vaccinated by our dealers during the repair of the vehicle?
    If you press a button on a small flap, it opens or not? Can you hear any lock on the lid?
    The layout is a bit strange: it consists of a tailgate lock and a tailgate lock in the tailgate. They are controlled separately, and this is understandable (lid button - lid lock, buttons in the lid lid - lid latch). On the other hand, the opening microswitches are built inside locks and information from them is connected to one wire. So the system does not distinguish what is open.
    One thing is certain (see owner's manual). "Opening the tailgate
    it is not possible if the cover is there
    open or not closed properly. "
    So it looks like the system waits for information from any lock about opening the lid or the hatch and its re-closing and blocks the operation of the hatch lock and the covers for this time.
    you have to undress - get to the locks, observe whether there is voltage to the lock of the damper cover, measure the limit switches on the closed locks or shorten to ground, or simulate the microswitches and see what the system does.
  • #4 16332307
    zagtom
    Help: 6
    Rate: 28
    Today I was able to manually open the little hatch and now I have access to its lock. The case is as follows: the small hatch lock motor is dead - it does not respond to 12V, after pressing the open button small nap flap comes, the end stop in the castle is ok. I will look for a lock and we'll see. With this large flap locking, it looks like the UCH is giving a nap. on the lock of the small flap while blocking the opening. large until the small limit switch shows that the damper has been opened and then closed. In my case, damage to the lock motor causes the limit switch to be immobile, so the UCH is waiting and the big one is blocked.
  • #5 16332553
    kamiloskop
    Help: 42
    Rate: 279
    Change .. we'll see
  • #6 16341436
    zagtom
    Help: 6
    Rate: 28
    A functional lock for a small flap (fits Laguna2) and the problem is gone.
