Renault Megane Scenic 1998 2.0 Gasoline: Ignition and Central Locking Issue - Unable to Start Car
gudaxo 8994 5
  • #1 16270361
    gudaxo
    Hello!
    I would like to consult you. Namely, the case is that I have a Renault megane scenic 1998 2.0 car in gasoline. To start the car, you need to double-click the button on the key which is used to remotely lock / unlock the doors. The problem is that something has happened to this "module" in the car and the button in the key does not work, so the door does not open or the car does not start (this is somehow interlocked. The batteries in the key were replaced and nothing It didn't work. Do any of you know how to turn it off completely? I can't start the car at all. I have a diagnostic cable, so if it is possible, I would like to do it myself, because there is no money for mechanics. Please help. Thanks in advance!
  • #2 16270396
    brofran
    Help: 650
    Rate: 1407
    Do you have a built-in anti-theft alarm system? After opening the door with the key, this also happens, do all the doors unlock?
    Moderated By ociz:
    It is about factory protection, not Chinese food.
    3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #3 16270402
    wtełek1
    Help: 19
    Rate: 55
    It would be good if you knew the model of the control panel.
    Usually, they have such alarms, additional two wires to disconnect, for example, the fuel pump or the impact sensor. Maybe it will direct you to something :)
    So if you knew, for example, What is this control panel, you could disconnect the above cables and it should work.
    Moderated By ociz:
    As above.
  • #4 16270405
    gudaxo
    There is no alarm. From the driver's side, when you open the door with the key, all the doors open, but the lock is broken on the driver's side, so I open it from the passenger's side, then only the passenger opens. This entire module is next to the interior rearview mirror. It can be removed.
  • #6 16270757
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    See yourself to the ir receiver in the headliner next to the lamp, whether it is floating
