Deleting Windows.old Folder from New Laptop with Windows 10 Pro 64bit: Is It Safe?
wertiko7 8382 18
Can I safely delete the Windows.old folder from a Windows 10 Pro 64-bit laptop, and why is it there on a new laptop?
Yes, you can delete the Windows.old folder without damaging Windows, but first check whether it contains any personal files, settings, or data you want to keep from a previous installation or update [#16482873][#16483807] In this thread, it was noted that the folder may include leftovers from an older system or from a recent Windows update such as the Creators Update, which can create about 20 GB of old files [#16482873][#16483877][#16484047] The folder shown also contained files from a previous user profile, which confirms it can hold data from an earlier system state [#16483807] It does not contain system restore files, so deleting it will not remove your ability to restore Windows in the usual restore-point sense [#16483957] If you want protection before deleting, create a separate system restore point first [#16483957]
  • Windows.old indicates a previous Windows installation
    #1 16482861
    wertiko7
    Rate: 100
    I found a folder called Windows.old on my C drive which takes almost 20 giga.
    I was a bit surprised because I have a new laptop with Windows 10 pro 64bit.
    And on the net I read that these are the remains of old Windows, e.g. 7 or 8.
    So there shouldn't be a folder on a new laptop.
    Was there a different system on the new laptop before? Is that how I understand it?
    And can I delete this folder without damaging Windows?
    Windows 10 Pro 64bit.
  • #2 16482873
    DriverMSG
    Help: 3984
    Rate: 4887
    Was it new with this system?
    See the contents of the Windows.old folder. There may be data, documents, settings etc. from the previous system.
    Yes.
  • #3 16482880
    wertiko7
    Rate: 100
    It was so new, I bought it 2 weeks ago the laptop looked like new.
    And under the laptop there is even a sticker with the logo of the X-kom store with the Windows key.
  • #4 16482889
    DriverMSG
    Help: 3984
    Rate: 4887
    Just in case, show us the SMART disk. We'll find out if this looks new.
  • #5 16482904
    wertiko7
    Rate: 100
    Deleting Windows.old Folder from New Laptop with Windows 10 Pro 64bit: Is It Safe? This is how it looks. Is everything OK?
    And this is the contents of the Windows.old folder. What to get in to see if there was any other system?
  • #6 16483023
    DriverMSG
    Help: 3984
    Rate: 4887
    Show contents of Windows and Users folder.
  • Asking whether the folder can be deleted
    #7 16483034
    wertiko7
    Rate: 100
    Windows content.
    Deleting Windows.old Folder from New Laptop with Windows 10 Pro 64bit: Is It Safe? Deleting Windows.old Folder from New Laptop with Windows 10 Pro 64bit: Is It Safe? Deleting Windows.old Folder from New Laptop with Windows 10 Pro 64bit: Is It Safe? Deleting Windows.old Folder from New Laptop with Windows 10 Pro 64bit: Is It Safe? Deleting Windows.old Folder from New Laptop with Windows 10 Pro 64bit: Is It Safe?
    Content of users.
    Added after 5 [hours] 15 [minutes]:
    So how about this folder, can you delete it or not?
  • Windows.old contains previous user profile data
    #8 16483807
    DriverMSG
    Help: 3984
    Rate: 4887
    In the Windows folder you have the file explorer.exe - you can compare it with yours and or check its version.
    In the Users folder you have the folder of the previous user "gryfi", that is, someone has already logged into the old system on this disk.
    I already wrote - Yes.
    You can delete, I drill topic to find out what this folder does on the disk of a new laptop.
  • Creators update likely created the Windows.old folder
    #9 16483813
    wertiko7
    Rate: 100
    Gryfi user is me.
    I read somewhere else that Windows 10 pro also creates the Windows.old folder.
    I will throw it when I find it.
    Added after 6 [minutes]:
    I found this text in an article.
    Added after 5 [minutes]:
    I can't open explorer.exe but I can see the creation date on it, it was created 3 days ago, it's like these files are mine.
    And 3 days ago I had creators update.
    Maybe it has something to do with it.
  • #10 16483877
    DriverMSG
    Help: 3984
    Rate: 4887
    Probably yes. File updates can make such copies of the system.
    If there are no files in your folder that you prefer not to lose, then you can delete the whole.
  • #11 16483900
    wertiko7
    Rate: 100
    Are there any system restore files in this Windows.old folder?
    I am a bit afraid that if I delete it, I may not have the option to restore the system in the event of a failure.
  • #13 16483990
    wertiko7
    Rate: 100
    Ok thanks for help.
  • #14 16484047
    r103
    Level 37  
    Help: 283
    Rate: 968
    I also got a few days ago updated "seriously" win10 including "creators update" - that is, it turned off 10 times with this update.
    And I'm checking it - in cleaning the disk "clean system files" - there were about 20 GB of old files from before the update.
  • #15 16484122
    wertiko7
    Rate: 100
    Is this Windows.old folder created before or after creators update?
  • #16 16484246
    r103
    Level 37  
    Help: 283
    Rate: 968
    Well, rather because I noticed that the disk "decreased" by 20 GB which with a 120 GB SSS drive was not difficult :-)
  • #17 16484816
    wertiko7
    Rate: 100
    Have you previously had another version of Windows on this drive?
  • #18 16485011
    r103
    Level 37  
    Help: 283
    Rate: 968
    Well, I do not know what's going on - but I serve: this disk was in another computer and the current one is win10 all the time I think there was an update that you had to install again because everything broke :-)
  • #19 16977735
    wertiko7
    Rate: 100
    Ok thanks for help.
The discussion revolves around the presence of a Windows.old folder on a new laptop running Windows 10 Pro 64-bit, which is taking up approximately 20 GB of space. The user is concerned about whether this folder indicates remnants of a previous operating system and if it is safe to delete it without harming the current Windows installation. Responses confirm that the Windows.old folder can be created during system updates, such as the Creators Update, and may contain user data from a previous installation. Users are advised to check the contents of the folder and ensure no critical files are present before deletion. It is also suggested to create a system restore point as a precaution before proceeding with the deletion.
