Infrared Dash Cam/Car Camera: Seeking Recommendations for Night Vision Devices in Total Darkness
sauber94 5160 9
Can I buy a car dash cam with infrared that records usable video in complete darkness, and what should I expect from it?
A typical car dash cam with built-in infrared will not record well in total darkness; to see anything useful you need a decent external infrared illuminator, and even then the usable range is only a few meters, sometimes around 2 m [#16483414] [#16543145] The reason is that in a car the IR light often reflects off the windshield and makes the image hazy [#16543145] One reply said not to expect such a device for up to PLN 200, while the budget mentioned by the asker was about PLN 400 [#16483414] [#16483429] Some users recommended Xblitz models such as Xblitz GO Full HD / Xblitz for around PLN 349–400 as having a night mode and acceptable night performance, but these suggestions were based on general impressions rather than verified tests in total darkness [#16511492] [#16513152] [#16542493]
  • #1 16483362
    sauber94
    Hello, I need to buy a video recorder / car camera with an infrared function so that at night in a total darkness something can be seen. There are a lot of devices equipped with infrared, but I could not find any video on youtube that would show how such a thing behaves at night in the total lack of light.
  • Need for a separate infrared illuminator
    #2 16483414
  • #3 16483429
    sauber94
    Let's assume about PLN 400 for the budget. I don't know honestly. For PLN 200, I would not even buy an ordinary one because I know that it has poor recording quality even during the day.
  • #4 16511492
    rotten21
    for PLN 349 at Frago.pl you have a pretty cool xBlitz car camera I think it will meet your expectations :)
  • #5 16513152
    Brozerihno
    Help: 28
    Rate: 44
    Xblitz GO Full HD / 2 "/ 170 for less than PLN 400 there is a night mode in it, just enter on YouTube there are movies from night and day.
  • #6 16513295
    sauber94
    My point is that it should be able to cope in complete darkness without any lights in the car or on the road.
  • #7 16513339
    Brozerihno
    Help: 28
    Rate: 44
    I do not know I did not test I gave you what I think is good at this price, see tests on YouTube, the best
  • #9 16543145
    mariann
    Help: 551
    Rate: 649
    sauber94 wrote:
    I need to buy a video recorder / car camera with an infrared function to see something at night in the total darkness
    How far should something be visible?
    Rafiik89 wrote:
    I have Xblitz Go Full HD and it is doing well, in complete darkness it also does the right thing
    Usually, a video recorder mounted in the car copes very badly in complete darkness. First, infrared illuminates the glass pane first, and the reflected light makes the image a bit hazy. Secondly, the power of the illuminator at the video recorder is very small. Outside, in complete darkness, the range of such an illuminator is several meters. Sometimes 2 meters. Depends on the recorder model.
  • #10 16546200
    Rafiik89
    I have to disagree here :) yes, it is known that it will not be perfect, but mine is really good, the image may not be perfect, but the visibility is maintained :) this xblitz camera that I linked is not bad.
The discussion revolves around finding a car camera with infrared capabilities suitable for recording in total darkness. The initial inquiry highlights the difficulty in locating effective devices, particularly those that perform well without any ambient light. Participants suggest a budget of around PLN 400, with recommendations for the xBlitz brand, specifically the xBlitz Go Full HD model, which is noted for its night mode functionality. However, there are concerns regarding the limitations of infrared illuminators, which may only provide visibility for a few meters in complete darkness. Despite these limitations, users report satisfactory performance from the xBlitz camera in low-light conditions.
