How to Use IP Night Vision Camera as USB Webcam on Linux for Computer Vision?
393 6
  • Need a USB camera with true night vision
    #1 21678003
    Cio Lop
  • Suggesting a USB-to-ethernet adapter workaround
    #2 21678004
    Aubrey Kagan
  • Suggesting WiFi-to-USB or analog capture options
    #3 21678005
    Rick Curl
  • Suggesting IR LEDs with a USB camera instead
    #4 21678006
    David Ashton
  • Need a USB camera without built-in IR filter
    #5 21678007
    Cio Lop
  • #6 21678008
    David Ashton
  • #7 21678009
    Rick Curl
The discussion addresses the challenge of using an IP night vision surveillance camera as a USB webcam on Linux for computer vision projects requiring night vision capabilities. The main issue is the lack of USB webcams with built-in night vision and infrared (IR) sensitivity comparable to IP cameras equipped with IR LED arrays. Attempts to modify USB cameras by removing IR filters or adding external IR LED modules have not yielded effective full darkness imaging. Suggested solutions include using USB to Ethernet adapters to connect IP cameras, employing WiFi-to-USB dongles for wireless IP cameras, or utilizing analog night vision cameras with analog-to-USB capture devices if the computer supports analog input. Vehicle reversing cameras with built-in IR LEDs were mentioned as low-cost alternatives, though typically with lower resolution and analog output. Caution is advised regarding image orientation in some USB night vision backup cameras. Brands like Logitech were referenced in testing scenarios, and online marketplaces such as eBay were noted for sourcing inexpensive night vision cameras.
