Lemfo LEM5 Firmware Replacement: GPS Fix, LES1 Code Integration, Tools like Odin
dziechu 4944 6
  • #1 16494873
    dziechu
    Help: 27
    Rate: 71
    I have a Lemfo LEM5 smartwatch. Overall pretty cool except for one drawback - GPS is practically not working. This is a firmware problem that is often featured on forums. Sometimes the GPS works normally, it catches the fix in 2-3 minutes. But usually it can see 13 satellites, but all of them have a signal level of 0. You can wait an hour, in an open space, in a cloudless sky ... and nothing. I have modified firmware, partly using the code from LES1, another model from this company. I'd like to replace it, but I'm not sure what tools to use. I have already replaced firmware in my various devices, but I do it once a year and I am not very sure. For example, can I do it with Odin or another, what version and with what options, etc. It is described here - 13th or 14th post from the top (Damon), but he writes that he does not give detailed instructions, because you can find one everywhere ... .
    https://w3bsit3-dns.com/forum/index.php?showtopic=787623&st=1400
    This is what the contents of the folder with firmawaru files looks like:
    Please help :)
  • #2 16495204
    nutergsm
    Help: 1034
    Rate: 1663
    You must use the Smart Phone Flash Tool.
  • #3 16495217
    dziechu
    Help: 27
    Rate: 71
    Ok. Should it see the smartwatch after connecting? Probably some other USB driver is needed.
  • #4 16495389
    nutergsm
    Help: 1034
    Rate: 1663
    MediaTek USB VCOM Driver
    Search on google.
  • #5 16495394
    dziechu
    Help: 27
    Rate: 71
    After connecting the smartwatch to USB, something should communicate? For now I have something like this and I don't know what to do next.
    nutergsm
    Help: 1034
    Rate: 1663
    After loading the files to the program, click dwonload and connect the disabled smartwatch.
  • #7 16495659
    dziechu
    Help: 27
    Rate: 71
    OK thanks. I have loaded a new firmware.
✨ The discussion revolves around the Lemfo LEM5 smartwatch, specifically addressing issues with its GPS functionality, which is often unreliable. The user has attempted to modify the firmware using code from the LES1 model but seeks guidance on the proper tools for firmware replacement. Responses suggest using the Smart Phone Flash Tool and the MediaTek USB VCOM Driver for successful connection and flashing. Users are advised to load the firmware files into the program, initiate the download, and connect the smartwatch to proceed with the update.
