[Solved] A510F - How do I disable "FRP LOCK" from the dowload mode level?
kubek22222 9165 7
  • #1 17109669
    kubek22222
    Rate: 8
    Hello, I wanted to bypass Google account security in my Samsung a5 (2016). As the phone had an android 7.0, all the ways with yt / gogole did not work.
    I decided to upload the softa (from the official samsung website), with android 5.1.1 and here the whole problem begins.
    1. I downloaded soft - A510FXXS2APD1
    2. I ran the odina (version 3.12.3)
    3. Phone in download mode (usb drivers I had already installed)
    4. Everything is set as it should be and after clicking "start" the red "FAIL" pops up. A "SYSTEM REV. CHECK FAIL. DEVICE 1, BINARY 0" error popped up on my phone.
    After this unsuccessful attempt I wanted to start the phone and I get an error: "An error has occured while updating the device software."
    From what I managed to read, the bootloader is blocked, which does not allow the installation of a lower version of the android than the one that was default on the phone.
    Unfortunately, I tried to upload various softs one and four files (android 7.0) and it is still the same problem.
    There are various problems with different softs, for example:
    1.soft with android 5.1.1 - "SYSTEM REV. CHECK FAIL. DEVICE 1, BINARY 0"
    2.soft with android 6.0.1 - "SYSTEM REV. CHECK FAIL. DEVICE 5, BINARY 4"
    3.soft with android 7.0 - "SYSTEM REV. CHECK FAIL. (BOOTLOADER)
    I tried to disable this FRP LOCK with Odin, but on the phone every time a message pops up that FRP has blocked this action.
    Maybe someone is able to help? :)
  • #2 17109689
    nutergsm
    Help: 1034
    Rate: 1663
    And what did you do that for? Did you want to underestimate the firmware so that the previous ways to remove the frp block would work?
    Try to update the firmware with Samsung Smart Switch. if it does not work, it remains a visit to the site.
  • #3 17109720
    kubek22222
    Rate: 8
    That's exactly what I wanted to do, because I read that it was the only option to avoid this blockade.
    Unfortunately, Smart Switch and Kies do not want to cooperate - they do not recognize the device in both.
  • #4 17109805
    nutergsm
    Help: 1034
    Rate: 1663
    You had to check beforehand if you can underestimate.
    Now, as I wrote to go to the site, maybe something will do.
  • #5 17109844
    tino2003
    Admin of GSM Group
    Help: 1972
    Rate: 2087
    If you know what network the phone comes from, then the sound of such branded software can put it on your feet, if it fails, the answer is higher.
  • #7 17109918
    tino2003
    Admin of GSM Group
    Help: 1972
    Rate: 2087
    So upload 7.0 at Orange from 2018-03-04 because it is the highest available.
  • #8 17110502
    kubek22222
    Rate: 8
    Managed to! I downloaded a soft 4 file, thrown in the same way as in the instructions, but again it was crashing. Something occurred to me to throw only the "AP" file and somehow it went, thanks a lot! :)
✨ The discussion revolves around bypassing the Factory Reset Protection (FRP) lock on a Samsung A5 (2016) model A510F, which is running Android 7.0. The user attempted to downgrade the firmware to Android 5.1.1 using Odin (version 3.12.3) but encountered a "FAIL" error due to a blocked bootloader, preventing the installation of an older Android version. Suggestions included using Samsung Smart Switch for firmware updates, but the user faced recognition issues with the software. Eventually, the user found success by uploading only the "AP" file from a four-file firmware package, resolving the issue.
