New Map Update for Tomtom One 4N00.004.2: Europe Central 920_5267 Replacement
lord232! 4482 9
Which newer TomTom map can replace Europe_Central_920_5267 on a TomTom One 4N00.004.2?
The only specific replacement map mentioned is Poland_990_8306, which one user says fits [#16504119] However, other replies say older TomTom One/GO devices with 32 MB RAM are no longer supported in TomTom HOME, so available map options may be limited [#16497986] The advice given was to check TomTom’s website, use TomTom HOME/MyDrive Connect links, or contact TomTom customer service for current map availability [#16497056][#16497856]
  • #1 16496834
    lord232!
    Help: 107
    Rate: 178
    Hello. What is the new map for Tomtom One 4n00.004.2. I currently have a map: Europe_Central_920_5267. Pos.
  • #2 16496928
    Krzys55
    Help: 89
    Rate: 303
    You can check on the manufacturer's website.
  • #3 16497022
    lord232!
    Help: 107
    Rate: 178
    How could I, I wouldn't ask. Please link to the topic.
  • #5 16497766
    lord232!
    Help: 107
    Rate: 178
    MyDrive Connect is not supported by my navigation, but TomTom HOME. And after installing TomTom HOME, there is no information about which map is available.
  • #6 16497832
    Krzys55
    Help: 89
    Rate: 303
    I don't know what your navigation looks like but I used to make updates via TomTomHome (map purchase). If you have an SD, you put it into your computer, if not, you connect the navigation via USB. You create a tomtomhome account, log in and have it all.
    Added after 5 [minutes]:
    https://pl.support.tomtom.com/app/answers/detail/a_id/15335/locale/pl_PL
  • #7 16497847
    lord232!
    Help: 107
    Rate: 178
    Yes, I know only about the version of the map that is available and there is zero information about its version. I don't want to throw the money away.
  • #8 16497856
    Krzys55
    Help: 89
    Rate: 303
    There used to be versions of the map available, now I don't know. Call us for info or write an e-mail to the Customer Service Center.
  • #9 16497986
    koala106
    Help: 471
    Rate: 1240
    Tomtom has not supported old One and GO devices in Tomtom Home for some time. Especially devices with 32 MB RAM.
  • #10 16504119
    lord232!
    Help: 107
    Rate: 178
    As far as I know, Poland_990_8306 fits. Pos.
The discussion revolves around finding a new map update for the TomTom One model 4N00.004.2, specifically seeking a replacement for the existing Europe_Central_920_5267 map. Users suggest checking the manufacturer's website for updates, but the original poster indicates that their device is not supported by MyDrive Connect and only works with TomTom HOME. There is uncertainty regarding the availability of new map versions, with one user mentioning that Poland_990_8306 may be compatible. It is noted that TomTom has ceased support for older devices, particularly those with 32 MB RAM.
