TomTom GO 520 WIFI - Failed Map Update, No Map Available, Lifetime Service, 17.100.0022.044
asdros 5835 6
  • Map update failure leaves TomTom with no maps
    #1 16489047
    asdros
    Hey. I own the TomTom GO 520 navigation with WIFI and a lifetime map and speed camera update service.
    There was a failure message updating the map today. I normally restarted the device and my eyes noticed very bad news: "NO MAP AVAILABLE, Add one or more maps before using the device".
    Below is the "add map" button that doesn't work. Namely, when pressed, the display dims for a few seconds, and then displays information about the update weighing about 350 MB and the designation 17.100.0022.044. Unfortunately, I can't install it because after a while a message about missing maps appears.
    I have already tried to restart the device, i.e. by holding the ON / OFF key for over 30 seconds, but this does not solve the problem.
    I'm not a specialist in this field, but I suspect it's a firmware bug.
    Has anyone had contact with this type of problem and would like to share their experience?
    Greetings.
  • #2 16489817
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    5 things:
    1.restart navigation as you wrote
    2. close the mydrive connect peogram - also kill in task manager
    3. enter the location where the data is saved - probably C: / Users / user / AppData / Local / TomTom / HOME3 / cache - delete everything that is there.
    4. Restart it ie MDC
    5.plug the navigation and let it update again
  • #3 16489864
    Freddy
    Help: 1394
    Rate: 2822
    Was this version no registration required to get LTM?
  • #4 16489925
    asdros
    tomrom1985 - I followed your instructions and the update started. At the moment, the process is at 36%, but I see in the task manager that the MDC program is working intensively (network usage at 25 Mb / s).
    Freddy - it's exactly as you write. Mine was registered about three months ago.
  • #5 16490130
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    MDC can plow a processor. On my i7 and 16GB Ram I often feel a hell on the side of my laptop. Patience - it will be okay
  • #6 16490174
    koala106
    Help: 471
    Rate: 1240
    For me, MDC on i7 3810 and 16gb ram does not show anything during the update. In general, the most important is a fast and stable internet connection. For me, UPC flashes perfectly, and for friends with other operators - dialogue or Orange is a failure. The update breaks and you have to combine several times.
  • #7 16490216
    asdros
    The update has ended and the device has already started correctly :D .
    Problem solved, topic closed.
    Thank you for your interest.
The discussion revolves around a user experiencing a failed map update on their TomTom GO 520 navigation device, which resulted in a "NO MAP AVAILABLE" error message. The user attempted to resolve the issue by restarting the device and using the "add map" function, but encountered further problems. Several community members provided troubleshooting steps, including restarting the navigation device, closing the MyDrive Connect (MDC) program, clearing the cache, and ensuring a stable internet connection for updates. After following these suggestions, the user successfully completed the update process, resolving the issue.
