Experiencing Short Circuit After Attempting to Install Pioneer MVH-190UB Radio in Audi a3 8l
addio 10659 9
How can I diagnose why an Audi A3 8L radio stopped working after a short circuit during Pioneer MVH-190UB installation?
Check whether the radio has a permanent +, an ignition +, and a ground, and verify the radio fuse plus any additional fuse at the socket; in the thread, fuse 42 and then 37 were specifically checked, and all fuses should be removed and tested with an ohmmeter if needed [#16505156][#16505947][#16506396] Before doing any wiring work, disconnect the battery negative clamp, because a bad connection can damage more than the fuse [#16505227] If the fuses are good, test the socket with a bulb or meter between ground and the red/white, blue-gray, and black wires with ignition on; if power is missing there, the ignition cube/contact S may be damaged [#16506473] The final diagnosis in the thread was that there was no power to keep the radio memory, so it was connected without that feed and had to be switched on and off from the button [#16510020] If you are not comfortable checking wiring and power feeds, take it to an electrician [#16505156]
  • #1 16499073
    addio
    Hello, I wanted to exchange the radio in my connection from some noname to Pineer [MVH-190UB], after connecting the new 0-reaction radio (it was checked at a friend in Nissan and it works), the old radio worked normally, I found that probably the wrong cables go in the iso connector , while trying to "tune up" the cables so that they would go well, I accidentally touched 2 and there was a short circuit, since then no radio works, fuses ok. The connector iso I already have a new one. Experiencing Short Circuit After Attempting to Install Pioneer MVH-190UB Radio in Audi a3 8l
    I do not know electricity, my knowledge ends with the fact that for something to work, it must have + ^^
    This is how the connector coming out of the car looks like:
    Experiencing Short Circuit After Attempting to Install Pioneer MVH-190UB Radio in Audi a3 8l Experiencing Short Circuit After Attempting to Install Pioneer MVH-190UB Radio in Audi a3 8l Experiencing Short Circuit After Attempting to Install Pioneer MVH-190UB Radio in Audi a3 8l
    And this is the radio cube: Experiencing Short Circuit After Attempting to Install Pioneer MVH-190UB Radio in Audi a3 8l
    Any advice what can I check or do? Is it better to take it to an electrician?
    PS. Maybe someone from Gliwice and could check it in case of what?
    wzielonymgaju18
    Help: 32
    Rate: 110
    Perhaps there is also a fuse at the ankle, check if there is a ground (-) and a permanent plus, plus a ignition switch. But if you don't feel up to it, take it to an electrician or someone who knows electricity, because bad connection in extreme cases can even start a fire.
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    addio wrote:
    when trying to "tune" the cables so that they went well, I accidentally touched 2 and there was a short circuit,
    We take the mass clamp from the battery before this type of work.
    addio wrote:
    fuses approx
    Have you identified all the fuse boxes in the car? Are you able to indicate the fuse from the radio? Wasn't he "tied" with a paperclip?
  • Asking whether the radio fuse is in the under-hood box
    #4 16505693
    addio
    All that is? One is inside (on the side of the cockpit), the other is a box under the hood. I checked the inside according to the diagrams from the forum, when I checked fuses from lights, etc. I didn't check those under the hood, but I looked at them with my eye, from what I remember now they were only safe "cube-like", there were no 10A / 15A types, etc., although there is a place for them, which surprised me a bit .
    What do you mean by writing
    Schemes I used:
    jdubowski
    Help: 2511
    Rate: 2804
    addio wrote:
    Schemes I used:
    And where did you find the fuse from the radio?
    If you are sure that it is there (but the description is so twisted that it does not identify it), then you need to remove all fuses one piece and check each with an ohmmeter.
    If a wire is inserted instead of a fuse, then something else burns instead of the fuse.
  • #6 16506262
    addio
    Yes, number 42, I tried to swap it with others, to no avail.
    jdubowski
    Help: 2511
    Rate: 2804
    Still No. 37 Checked?
  • #8 16506415
    addio
    Yes. To be sure, I checked all the fuses. There are no burn marks at all. Like New.
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Take the bulb from the front parking lot and check that it lights up with the ignition on, the lights on when you connect it between ground and red and white, ground and blue-gray, and ground and black in a cube with 4 wires.
    If the fuses are in working order, the ignition cube could be damaged - the S contact.
    When you check the above-mentioned ones, you will know what is missing and where to look.
  • #10 16510020
    addio
    Thanks to everyone for the answers, situation solved. I drove to a friend of a mechanic, diagnosis - No power to keep the memory of the radio, somehow connected me without it, but just like in the previous radio, I will have to turn the radio on and off from the button. I just wonder why this is so, since there were no connected cables on the previous radio, as he did now, and I had to run the same from the button. Thanks again to everyone.
The discussion revolves around a user who experienced a short circuit while attempting to install a Pioneer MVH-190UB radio in an Audi A3 8L. After connecting the new radio, which worked in another vehicle, the user encountered issues likely due to incorrect wiring in the ISO connector. Following a short circuit incident, the radio and possibly other components ceased to function, despite the fuses being intact. Various responses suggested checking the fuses, ensuring proper grounding, and verifying the ignition switch connections. Ultimately, a mechanic diagnosed the issue as a lack of power to maintain the radio's memory, leading to a workaround where the radio must be manually turned on and off.
