Api-ms-win-core-synch-l1-2-0.dll Missing Error: Causes & Solutions in Skype & Minecraft
rezoRSHL 7173 4
  • #1 16510276
    rezoRSHL
    Level 4  
    Rate: 8
    Hello, I have been struggling with a problem for some time. At the start of the system, two pop-ups with the same content pop up:
    This application failed to start because api-ms-win-core-synch-l1-2-0.dll was not found. Re-installing the application may fix this problem ...
    more or less in this style.
    The location of this file is the Skype folder, more precisely the Phone folder. What can cause this error? I will point out that when I play, for example, a minecraft, talking on Skype, I get bsod REFERENCE_BY_POINTER. When I am not talking, this is not the case.
  • #2 16510288
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    Search the disk for files api-ms-win-core-synch-l1-2-0.dll and copy to the location where this file should be.
  • #3 16511075
    rezoRSHL
    Level 4  
    Rate: 8
    Api-ms-win-core-synch-l1-2-0.dll Missing Error: Causes & Solutions in Skype & Minecrafterror231..1.jpg (30.58 kB)You must be logged in to download this attachment.
    A small correction, twice the window as above appears and Skype starts.
    I was looking for this file everywhere and it is only in the Skype folder.
  • #4 16511086
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    Watpie, if you have FF or TB then you have the file in:
    C: \ Program Files (x86) \ Mozilla Firefox \ api-ms-win-core-synch-l1-2-0.dll
    or:
    C: \ Program Files (x86) \ Mozilla Thunderbird \ api-ms-win-core-synch-l1-2-0.dll
    Additionally:
    C: \ Windows \ system32 \ api-ms-win-core-synch-l1-2-0.dll
    C: \ Windows \ SysWOW64 \ api-ms-win-core-synch-l1-2-0.dll
    You can also install, for example, Paint.Net:
    C: \ Program Files \ Paint.NET \ SxS \ x64 \ api-ms-win-core-synch-l1-2-0.dll
    C: \ Program Files \ Paint.NET \ SxS \ x86 \ api-ms-win-core-synch-l1-2-0.dll
    You should also install all versions:
    Visual C ++ Redistributables (x86 and x64 - 2008, 2010, 2012, 2013, 2015)
    Both 32 and 64bit.
  • #5 18969939
    chlebok
    Rate: 56
    Davinci resolve
    Uninstalling and installing in the Program Files folder helped. Windows 7.
