Issue with TS3 .dll Files: Missing Library Files Solution after Computer Formatting
AAAdrianOOO 4485 10
How can I fix missing DLL library files in TS3 after formatting my computer?
Install the required Windows updates first, because TS3 may need Windows 7 SP1 and a fully updated system to provide the missing DLLs [#16282468][#16287185] If Windows Update is stuck, stop the Windows Update service and use the update-fix steps linked from Superuser to get the updates installed [#16296080] One reply identified the missing files as `api-ms-win-crt...dll` files and said a ready package can be added either by installing the small League of Legends client, which drops the needed `api-ms-win` files into its folder, or by using a package copied from `System32` on another Windows 7 64-bit machine [#16307690] After the DLL problem disappeared, the game still showed that the application was launched incorrectly, so the DLLs were not the only issue [#16308527]
  • #1 16273163
    AAAdrianOOO
    by format computer disk I have a problem running TS3. It keeps showing me the missing file from the .dll library. I've already downloaded many files, but I'm sick of it. Is there a packet of these files?
  • #2 16282468
    toska78
    Help: 29
    Rate: 31
    If you have Windows 7, SP1 is required.
  • #3 16283115
    RADU23
    Help: 2428
    Rate: 1732
    More specifically
  • #4 16286569
    AAAdrianOOO
    I have SP1.
    I miss a lot of files, which I will not upload a new one.
  • #5 16287185
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    By such "uploading" random files you can damage your system.
    Have you installed all updates with Windows Update?
  • #6 16296071
    AAAdrianOOO
    I have already tried installing these updates once. The first time they all downloaded (1.5 GB), but they did not install. All day 0%. Now it shows me that I need to download 700 MB, and the whole day is 0% download ...
  • #8 16306656
    AAAdrianOOO
    Installations supposedly installed from what I downloaded. TS3 still does not work, and when I turned on WU after a while, it shows me 111 updates.
  • #9 16307579
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    > WU it shows me 111 updates.
    Can you install them?
  • #10 16307690
    bartoszkola621
    You are probably missing the api-ms-win-crt ... dll files. You can download a ready package in two ways:
    1. The client of the popular MOBA network game called League of Legends is based on these drivers and when the client is installed (max 50 MB), the installer adds all necessary api-ms-win files to the client's folder, then you know what to do about it.
    2. I can give you a link with a ready package copied from the System32 folder from my computer that is running TS (Win 7 64-bit).
  • #11 16308527
    AAAdrianOOO
    Thanks a lot for this package, the problem of .dll files has disappeared, but now a window pops up that the application has been launched incorrectly. I open with the administrator of course.
The discussion revolves around issues with missing .dll files after formatting a computer, specifically affecting the operation of TS3 (TeamSpeak 3). The user reports difficulties in installing necessary updates for Windows 7 SP1, which are crucial for resolving the .dll file errors. Suggestions include ensuring all Windows updates are installed, stopping the Windows Update service to manually install updates, and downloading a package of required .dll files. A solution was found by downloading a package that resolved the .dll issues, but the user then encountered a new error indicating the application was launched incorrectly, despite running it as an administrator.
