Eliminating Spyware: Remove Unwanted IPs, Secure Passwords, Using Windows Defender & McAfee
Arturowski333 7689 8
  • #1 16513336
    Arturowski333
    Rate: 9
    Hello!
    recently I have problems with spyware. I see in history how to enter on the Internet from various IPs.
    Changing passwords does not give anything, so I guess I see new passwords.
    I am not giving anything to Windows Defender and McAfee scan.
    I admit that I am a novice, that's why I am asking for help!
  • #2 16513353
    Matuzalem
    Help: 1651
    Rate: 1098
    And for some particulars in the description and attachment, you can count on whether we have to believe that this is not a symptom of persecution mania?
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #4 16514859
    Arturowski333
    Rate: 9
    I have a problem with a spy program that logs on to social networks and emails. Please help.
    • FRST.txt (72.74 KB) You must be logged in to download this attachment.
    • Addition.txt (50.54 KB) You must be logged in to download this attachment.
  • #5 16515253
    Kolobos
    IT specialist
    Help: 17166
    Rate: 10445
    > who logs on social networks and emails
    Are you sure that it's not your addresses? Eg with login from the phone etc? Enter some addresses from which "someone" logs in.
    There is no infection.
  • #6 16515294
    safbot1st
    Help: 2719
    Rate: 1583
    Change passwords and do not log in with adventitious computers, disable password memorisation and automatic completion, etc. Maybe the "problem" will clear up.
    Do you have access to a computer?
    Post as you checked these IP addresses.
  • #7 16521304
    Arturowski333
    Rate: 9
    I did a screen IP which used my Facebook. my ip (82.139.721) Białystok Eliminating Spyware: Remove Unwanted IPs, Secure Passwords, Using Windows Defender & McAfee
    I checked the IP of logins from a mobile phone and there were strange locations such as Warsaw, Chorzów, Wroclaw. I am from Bialystok, also a bit suspicious.
  • #8 16521483
    Kolobos
    IT specialist
    Help: 17166
    Rate: 10445
    By logging in on the phone you can get a random address, it does not have to be from your city.
    It does not look like someone spies on you.
  • #9 16521679
    Arturowski333
    Rate: 9
    Ok. Thanks, nothing is happening right now :)
✨ The discussion revolves around a user's concerns regarding spyware, specifically unauthorized logins from various IP addresses on social networks and email accounts. The user suspects that changing passwords has not resolved the issue. Responses suggest that the user may be logging in from different devices, such as mobile phones, which can generate random IP addresses. Recommendations include changing passwords, avoiding logging in from unfamiliar devices, and disabling password memorization features. The user provided screenshots of suspicious IP addresses, but it was noted that these could be normal variations due to mobile network usage. Ultimately, the user reported no current issues after following the advice given.
