Replacement 24V Power Supply for Moovo MCI1 Gate Controller: Using Mean Well Products
saly 8052 2
  • #1 16516567
    saly
    Level 32  
    Help: 89
    Rate: 1003
    I have a problem, I had a power supply (damaged transformer) in the MOOVO MCI1 gate controller, or if any of you tried to use an external power supply, e.g. some 24V impulse power supply.
    Is the power supply in the Moovo MCI1 controller a 24V power supply, I have never measured the power supply how it worked.
    I thought to use something from industrial power supplies, eg MEAN WELL
    link
    But I don't know if it will work properly.
  • #2 16516583
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    It will work when you select one with the same voltage and similar power
  • #3 16549124
    saly
    Level 32  
    Help: 89
    Rate: 1003
    A 12V power supply is required for this gate controller.
    I used MEAN WELL EDR120-12, for a 3.5 meter gate this power supply has a lot of reserve and the gate automation works properly. The size of the power supply fits the driver perfectly, you only need to slightly move the housing with the original driver and give a piece of DIN rail to the motor housing.
