Samsung Smart TV 48H6400AW Stuck at Logo - Possible Network Update or Hard Reset?
krzys_20 10347 11
How can I recover a Samsung Smart TV that only shows the logo at startup and does not respond to the hard reset buttons?
Try a USB firmware update rather than a network update: format a pendrive as FAT32, copy `upgrade.msd` to the root with no folders, then plug it into the TV while it is off and press power [#16521596] If that does not start the update, unplug the TV from the mains, wait a few seconds, hold the power button, and reconnect it; another suggestion was to place `upgrade.msd` inside a `SERVICE` directory and try the TV’s local control/joystick or `OK` button instead of the power button [#16521596][#16525110][#16525153] One user also reported that Samsung service could remotely guide the set to accept the USB stick immediately after insertion, so contacting Samsung support may be the next step if the TV still only flashes the USB once and does nothing [#16525429]
  • #1 16521145
    krzys_20
    Rate: 10
    Hello everyone, I have a problem with the above mentioned model, i.e. Samsung Smart tv 48H6400AW, namely when I turn on the TV, only the Smart TV logo appears
    and the standby diode will flash momentarily. I have a network set up, could I do an update? Only my mother was at home and said that the TV did not turn on when it turned off, apparently there were no subtitles. What can I do with this phantom? Thank you for your help.
    Ps I will add that hard reset using info mute remote control etc. do not work
  • #2 16521562
    daro19862
    Help: 26
    Rate: 166
    You tried to upload firmware from THIS link?
  • #3 16521576
    krzys_20
    Rate: 10
    Hello, I will be home at Monday. I will try to do as you wrote, I was on this page and I read it, but thanks. I just thought someone had a similar problem. greetings
    Added after 6 [minutes]:
    And someone can know how to do it because when I tried to fire the flash drive there was no reaction. No manus can be accessed
  • #4 16521596
    daro19862
    Help: 26
    Rate: 166
    Format the pendrive for fat32, upload it to the upgrade.msd file without any folders.
    Connect the pendrive with the TV turned off and press power. If it doesn't move, connect the pendrive, disconnect the TV from the plug, wait a few seconds and holding the power button connect the plug to the contact.
  • #5 16525102
    krzys_20
    Rate: 10
    Hello, unfortunately none of these options worked. The flash drive for a moment only flashes once and nothing happens.
  • #6 16525110
    daro19862
    Help: 26
    Rate: 166
    Then maybe try to put the directory with the upgrade.msd file on the pendrive from the archive.
    Alternatively, name the SERVICE directory and insert the upgrade.msd file into it.
    I don't know exactly in this model what you need to press for TV to start downloading firmware,
    maybe instead of the power button, press "OK" if you have one on your local keyboard.
    Did you disconnect the contact plug?
  • #7 16525127
    krzys_20
    Rate: 10
    Local keyboard what is it?
    I have disconnected the plug
  • #8 16525153
    kassans
    Level 32  
    Help: 130
    Rate: 412
    The local keyboard is what's on the tv.
  • #9 16525155
    krzys_20
    Rate: 10
    there is nothing on the TV but a small joystick
  • #10 16525429
    Witold5
    Level 32  
    Help: 178
    Rate: 728
    In a similar situation, I called the Samsung service and the guest directed me so that during the conversation with him the TV accepted the pendriva immediately after inserting it into the USB socket on the TV. So maybe try calling the service.
  • #11 20740431
    jurex2
    Help: 10
    Rate: 9
    Hello everyone,
    I know this is a very archaic topic, but I have a question for my friend Witold. Do you remember what the update procedure was? I called Samsung's service center, but I guess I got a less intelligent operator because he couldn't help me. If you remember anything else, I would be grateful for the information.
  • #12 21309750
    richi63
    >>20740431 >>20740431 hello I am also interested in this procedure of connecting the pendrives with the software can you please give me a hint ?
The Samsung Smart TV model 48H6400AW exhibits a boot issue where it remains stuck on the Smart TV logo with the standby LED flashing briefly. Attempts to perform a hard reset using remote control key combinations failed. Users discussed updating the firmware via USB by formatting a flash drive to FAT32 and placing the upgrade.msd file either in the root directory or within a SERVICE folder. The update procedure involves connecting the USB drive to the TV while powered off, then powering on the TV or reconnecting power while holding the power button. Some suggested pressing the "OK" button on the TV's local control if available, but this model only has a small joystick. The USB update process sometimes requires interaction with Samsung service support to initiate firmware acceptance. Despite these methods, the update did not start, and the TV remained unresponsive. Later inquiries sought clarification on the exact USB update procedure due to limited support from Samsung service centers.
