Huawei P10 Lite Display Screen Repair: Replace Outer Glass vs Entire LCD, Instructions & Videos
Gama123456 10860 4
  • #1 16523881
    Gama123456
    A spiderweb appeared on the display screen after the fall. You can see the screen and the touch works.
    My question is whether it is necessary to replace the entire lcd? Is it possible to mention only the outer glass?
    Does anyone have an instruction for such an exchange or video?
  • #2 16524397
    KamGr
    Help: 77
    Rate: 203
    Video with the entire exchange operation:
    https://www.youtube.com/watch?v=sSWX_IEiqJ0
    And from what I see on auction portals, you can buy only entire sets, ie the display + touch, you probably will not exchange the touch itself.
  • #3 16807272
    nicek1991
    I exchanged the display in this model, the problem is that you need to have inhumane abilities and heat the phone in the oven, perhaps, to remove the whole panel without damaging the lcd itself. Then you would have to separate the LCD from the touch ... Personally, I recommend replacing the entire panel. Just to hawawiia are not terribly expensive.
  • #4 16808144
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    In this model, it is possible to exchange the surface fast itself, provided that all touch and lcd work. Of course you need to have the right equipment and skills.
  • #5 16808894
    nicek1991
    I agree, there is the possibility of such an exchange, but you must have a good separator and very good skills and spend a lot of time and patience which seems to me unprofitable, while the entire panel can be bought for about 100 PLN.
