Huawei P10 Lite: Tempered Glass Frame Issue - Explore Protective Film Alternatives
pytlowany1 7812 9
Should I switch from tempered glass to a protective film for a Huawei P10 Lite because the screen is curved and the glass leaves a dust-catching gap?
Yes — on this kind of curved screen, a good protective film/foil is the practical option because tempered glass will not fit flush and will leave a visible gap that collects dust [#17092340] If you still want glass, a 3D glass can cover more of the front panel, but it may still be about 1–2 mm smaller than the screen area [#16495660] There does not seem to be a glass variant that only sticks to the corners and fully solves the fit problem [#17092298] Some users keep the glass anyway because it is safer in a fall, but it will still have that imperfect edge fit [#16485815]
  • #1 16484591
    pytlowany1
    Rate: 91
    Hello. Recently, I put the tempered glass on the phone screen.
    Around there is a frame of a few mm glass deflection and everything is cut by the screen.
    Visually, it annoys me because it will get dust. Is it better to buy a protective film, will it be more tailored ??
    If the screen was quite flat - it would be ok.
  • #2 16484612
    kolibercio
    Help: 25
    Rate: 78
    P10 has Gorille Glass 5, in my opinion it is pointless to put on glass.
  • #3 16484672
    pytlowany1
    Rate: 91
    Are you sure? P10 definitely has but Lite probably not ..
  • #4 16485021
    kolibercio
    Help: 25
    Rate: 78
    In fact, I did not read. I pay you honor.
    Although even P9 lite has Gorille Glass 4, more P10 lite can have the same.
  • #5 16485815
    winmap
    Help: 361
    Rate: 753
    Unfortunately, with these strange lcd it is already. I do not know why these concave screens do. I have xperia xa and it is the same but I leave the glass that just is safer in the event of a fall.
  • #6 16488776
    pytlowany1
    Rate: 91
    However, I will replace it with 3D glass. I get dust around this frame, etc.
    It looks ugly.
  • #7 16488779
    mobista
    Help: 257
    Rate: 365
    And not rather convex?
  • #8 16495660
    pytlowany1
    Rate: 91
    I bought a 3D glass and it glues not only the screen but also the elements of the entire front panel.
    But further it is a minimally smaller glass by 1-2mm. Does anyone know 3D glasses that are stuck on the corners,
    Any specific brand?
  • #9 17092298
    Ordine
    Help: 75
    Rate: 164
    Any specific brand?
    There is no such and will not be
  • #10 17092340
    prezes94
    Level 19  
    Help: 22
    Rate: 64
    There is no medicine, good foil only.
The discussion revolves around the Huawei P10 Lite and the issues related to the installation of tempered glass screen protectors, particularly concerning the frame's deflection and dust accumulation. Users express concerns about the effectiveness of tempered glass given the phone's screen design, with some suggesting that the P10 Lite may not have Gorilla Glass protection. Alternatives such as 3D glass are considered, which adheres to the entire front panel but may still leave gaps. The consensus leans towards using high-quality protective films as a more suitable option to avoid dust and aesthetic issues.
