Fiat Grande Punto 2011 - Repair of the engine controller, no signal for the 4th
jacusix 16599 12
How can I repair an IAW 5SF9.A2 ECU when it has no output signal for ignition coil 4 on a 2011 Fiat Grande Punto 1.4 LPG?
The fault is most likely in the coil driver stage, not in a voltage regulator, and you need to identify which driver on the ECU board corresponds to coil 4 by using the wiring diagram or an ohmmeter from the coil pin to the ECU pin [#16527282] The coil output is on the large metal pads under those ST VB525SP elements, and the thread author found that pin 1 of coil 4 goes to the bottom of the outermost chip/driver [#16527282][#16527636] Replacing that driver fixed the ECU, and the donor board with the same VB325SP marking worked as a substitute [#16533492] So the practical repair is to replace the damaged coil driver associated with cylinder 4, or move to a compatible donor ECU/driver board if needed [#16527282][#16533492]
  • #1 16527225
    jacusix
    Help: 6
    Rate: 118
    Good day.
    Due to the fact that this is supposedly a fairly common problem, I decided to ask. Maybe someone will help :) Controller with the designation IAW 5SF9.A2 (IAW 5SF3.M1 donor bought)
    2011 Fiat Grande Punto car 1.4 + LPG. The engine controller does not give a signal to the coil going to the 4th candle (first from the right). When viewing the driver:
    Fiat Grande Punto 2011 - Repair of the engine controller, no signal for the 4th Fiat Grande Punto 2011 - Repair of the engine controller, no signal for the 4th Fiat Grande Punto 2011 - Repair of the engine controller, no signal for the 4th
    you can see 4 voltage regulators next to each other with the designation st mar vb525sp. As I guess, each voltage regulator has a separate coil. And that's what I am able to deduce for this time. Someone who is sitting on the topic certainly knows where to look for the fault. If anyone could help, I would be very grateful.
    sk700
    Help: 173
    Rate: 420
    You're going in the right direction.
    These are not voltage regulators but coil drivers.
    I haven't done it in the super dot yet, but in pandas they fall regularly.
    You need to determine which driver is responsible for this particular coil. Or, after the diagram, you will find out which pin of the connector is connected, or on the unplugged battery, connect the computer to the car and check with an ohmmeter to which driver is the transition from the wire controlling this particular coil.
    How do you determine which is the best solution?
    EDIT
    The coil output is the large plates under these elements.
  • #3 16527636
    jacusix
    Help: 6
    Rate: 118
    It is actually as you described :) I found pin 1 (described in the socket) from the coil 4 of the candle and it connects to the bottom of the extreme chip. Now I just need to get another driver, solder the chip and let you know the result :)
  • #4 16527923
    sk700
    Help: 173
    Rate: 420
    If you already have the driver disassembled, take accurate photos and rewrite the numbers from the sticker (because the search engine does not index the captions in the photos) - it may be useful to a person who burns an element and will look for its value :)
  • #5 16533492
    jacusix
    Help: 6
    Rate: 118
    I bought a second driver ... with an ignition switch and something else ... Otherwise they did not want to sell it to me because it is a set and they only sell it like that. But due to the fact that I paid PLN 120 for the set and it costs 200 + shipping on all-trade, it was not bad anyway ... The drivers included the designation vb325sp. Also the driver now works and I know that the systems with these markings can be interchanged. So they sold me damaged cables in the store, which they later replaced with another. One of the spark plugs purchased is or has been damaged, the computer is damaged, the timing is incorrectly adjusted ...
  • #6 16534101
    daras41
    Help: 57
    Rate: 315
    You can flip the layout, but it's easier to soft ;)
  • #7 16534237
    sk700
    Help: 173
    Rate: 420
    But you have to have something, a pendrive inserted into the radio will not do it, and if he had equipment, he would not ask such questions, he only replaced the driver and forgot about the topic :)
  • #8 16534556
    jacusix
    Help: 6
    Rate: 118
    You mean soft, i.e. the immobilizer? If I could see which bone he is in and if he can be soldered like this, I would probably do it but all this is knowledge and nobody wants to share this knowledge :P
  • #9 16534837
    adam7009
    Help: 656
    Rate: 1635
    It is in the ST10 bone ....
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #10 16535820
    daras41
    Help: 57
    Rate: 315
    Look for electronics in the area and you will make a clone. With soldering, that's more of a mess than it can be ;)
  • #11 16535944
    Frost160
    Help: 9
    Rate: 183
    And how "clone" in the sense of copying?
  • #12 16536008
    sk700
    Help: 173
    Rate: 420
    Yes, the programmer will transfer the content of the ST without physically replacing the system, but if the starter kit is available and costs PLN 120, it makes no sense because there is always the risk of releasing the controller when playing in programming ... this for PLN 50. Amen.
  • #13 21093518
    valentweety3
    hi can anyone send me an ecu pinout on the IAW 5SF9.AG ECU I THINK THEY ALL THE SAME AND CAN I USE ANOTHER IAW 5SF FOR MY 1.4 PUNTO EVO THANX
The discussion revolves around a common issue with the engine controller of a 2011 Fiat Grande Punto, specifically the lack of signal to the coil for the 4th spark plug. The user identifies the controller as IAW 5SF9.A2 and mentions using a donor controller IAW 5SF3.M1. Responses suggest that the components in question are coil drivers rather than voltage regulators. Users recommend checking the wiring and connections to determine which driver controls the faulty coil. The user successfully identifies the relevant pin and plans to replace the driver. Additional advice includes documenting component details for future reference and considering cloning the ECU if necessary. The conversation also touches on the interchangeability of driver models and the importance of proper soldering techniques.
