Hello, this error crashes to me and the engine works like a tractor, the fault is "mobile" once it is, once it is gone, the throttle is cleared to be sure, when the engine starts to vibrate, I disconnected the ignition coil pipe, there was no spark on the pipe 1 and 2 so I replaced the coil, but it didn't help, I read that it may be the computer's fault, due to the minus temperature, I haven't checked the wiring yet, has anyone had a similar problem?
ciapus4
ciapus4
Level 19
Help: 10
Rate: 42
