Locating Nichrome Wire: Are Pen Springs Made of Nichrome Material?
mateusz2015_5102 12765 9
Where can I find nichrome wire, and is a pen spring made of it?
No, a pen spring is steel, not nichrome. Nichrome (chromonickel resistance wire) is sold commercially by the meter and is used in medium- and high-power wire resistors and heating coils in heaters [#16534463][#16534466] If you only need a small amount, you can salvage it from a damaged heater, but then you may not know the exact alloy used [#16534463] Retail quantities of resistance wire are also available from many suppliers [#16534484]
  • #1 16534458
    mateusz2015_5102
    Pupil
    Rate: 81
    Hello, I am looking for nichrome wire but don't know where it can be found.
    I was wondering if the spring from the pen is nichrome wire.
    Please help.
  • #2 16534463
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    mateusz2015_5102 wrote:
    I am looking for a nichrome wire, but I don't know where it may be.
    In Polish it is called chromonikelin - Ni 80%, Cr 20% - iron-free or Ni 65%, Cr 15%, Fe 20% (ferric chromium nickel). Ask in companies selling resistance wire whether the resistance alloy is not enough for you. You can get a small amount from a damaged heater, "farelka" etc., but you will not be sure about the alloy used (if it is important).
    I was wondering if the pen spring is a nichrome wire
    No - it's steel.
    Please help.
    As part of the first aid I suggest a spelling dictionary - correct the subject because it bites in the eye.
  • #3 16534464
    mateusz2015_5102
    Pupil
    Rate: 81
    No - it's steel.
    Please help.
    I do not make mistakes in writing.
    And the resistance wire where can I get?
  • #4 16534466
    cooltygrysek
    Conditionally unlocked
    Help: 131
    Rate: 530
    Hello. Chromonickelin - a resistance alloy of nickel (80%) and chromium (20%) or simply chromium-nickel is found in medium and high power wire resistors, in all heating coils of heaters, etc. It is simply a resistance wire commercially available by the meter. There are round and flat wires with different resistance depending on the cross-section for a given section measured in centimeters or meters. There are two types of alloys - ferrous non-ferrous glycine, nichrome: Ni 80%, Cr 20% and ferric chromium glycine: Ni 65%, Cr 15%, Fe 20%.
    What does a friend need?
  • #5 16534469
    jdubowski
    Help: 2511
    Rate: 2804
    And the resistance wire skat can I take?
    But you knocked down ;)
    As for the source of resistance wire - you read with understanding my post
  • #6 16534473
    Zbigniew 400
    Help: 283
    Rate: 794
    What wire diameter?
  • #7 16534476
    cooltygrysek
    Help: 131
    Rate: 530
    With farelce it's not a good idea because overheated resistance wires like to break, it is suggested with a hair dryer that is thicker and easier to straighten by stretching the spiral.
  • #8 16534484
    jarek_lnx
    Help: 4199
    Rate: 6128
    Recently, resistance wires sold in retail quantities have appeared in the offer of many companies, all thanks to e-smokers who regularly burn their heaters and experiment with various wires.
  • #9 16534496
    cooltygrysek
    Help: 131
    Rate: 530
    jarek_lnx wrote:
    they regularly burn their heaters and experiment with various wires.
    Yes and then they overload the battery and boom in the face. Oh, there were such cases.
  • #10 16534558
    mateusz2015_5102
    Pupil
    Rate: 81
    Zbigniew 400 wrote:
    What wire diameter?
    0.1, 0.2, 0.3 mm
The discussion revolves around locating nichrome wire and clarifying whether pen springs are made of nichrome material. Participants explain that nichrome, known as chromonikelin, is an alloy consisting of 80% nickel and 20% chromium, commonly used in resistance wires and heating elements. It is suggested to source nichrome wire from companies that sell resistance wire or to salvage it from damaged heating devices. The conversation also touches on the availability of resistance wires in retail, particularly due to the needs of e-smokers. The author specifies wire diameters of 0.1, 0.2, and 0.3 mm, indicating a need for precise specifications.
