Mondeo mk3 1.8 16v gasoline 20 - Auto chokes when accelerating
zoltar67burek 7380 5
  • #1 16551976
    zoltar67burek
    Rate: 16
    When adding gas, the car chokes and jerks, but when the gas adds slowly, it does not jerk the worst at low revs, e.g. reduction from 4 to 3 at the intersection I use the pedal and the car jerks and chokes the gas, I have to slowly add and turn the engine on 2500 revs then goes candles new fuel filter what's going on too?
  • #2 16552013
    spinacz
    Help: 1204
    Rate: 2654
    And the pump doesn't end anymore? Check fuel pressure, diagnostics with actual values.
  • #3 16552192
    zoltar67burek
    Rate: 16
    Pump? But why only at low speed?
  • #4 16552267
    spinacz
    Help: 1204
    Rate: 2654
    Do diagnostics, maybe a flow.
  • #5 16554715
    zoltar67burek
    Rate: 16
    I think I did wrong cleaning the flow potentiometer on the throttle, I think that's what it's called, I sprayed it with a liquid for cleaning the throttle and carburetor and it suffocates so much from then on, but will it be? Diagnostics tomorrow
  • #6 16554749
    spinacz
    Help: 1204
    Rate: 2654
    It is very possible, these are not preparations for potentiometers. It is like rummaging the wrong way and the wrong way.
