Ford Mondeo MK3 2.0 Duratec AT - Maximum speed 2800. Throttling
Biturbo 7173 13
Why does a Ford Mondeo MK3 2.0 Duratec automatic with LPG choke and refuse to rev past about 3,000 rpm under throttle?
The cause was mechanical timing/valve damage, not a sensor or fuel issue: the timing belt tensioner was fully extended, the engine had lost synchronization, and the exhaust valves on cylinders 1 and 4 were burned, so the engine needed an overhaul [#16352035] The final diagnosis also found compression had dropped to 4–9 atmospheres, which explained why it would only cough on a couple of cylinders and then fail to rev properly [#16352035]
  • #1 16259932
    Biturbo
    I will describe the problem I have been struggling with for two days.
    Ford Mondeo MK3 2.0 Duratec automatic transmission. LPG sequence.
    The car's engine suddenly stopped turning over 3,000.
    At idle, it runs equally on gas and petrol.
    It fires at the touch. the rotation does not wave.
    Up to 3,000 it enters smoothly, but the more I open the throttle it starts to choke and jerk to the sides, then it drops from speed.
    No MIL / Check lamp.
    What I did or checked.
    After diagnosis with the AutoCOM computer, zero errors. Spark plug wires, new replaced 4 months ago
    Coil replaced with Original.
    Egr clean and functional.
    The MAP sensor is operational and cleaned.
    The throttle position sensor inside like new.
    The flaps in the collector were removed because they were already cracked, so I preferred not to fold them with them.
    The emphysema in the block is cleared. The suction tube is new
    Vacuum working.
    Tank vapor valve blinded momentarily - no change!
    Exhaust between the manifold and the angle unscrewed - no change
    The bone for the driver has been checked with zero raid or moisture.
    Compression pressure on cylinders 14/14 / 13,8 / 14
    Any disconnection of the sensor throws its error, so the driver and the harness work correctly, I explain.
    I exclude fuel pumps, injections, a rail with a valve because it is the same on LPG.
    The only thing left for me was the crankshaft position sensor strange indications of the ignition advance angle and possible replacement of the controller and the automatic controller or some blockade that does not allow to exceed certain revolutions.
    I am asking for some suggestions because if not, the car gives back elsewhere, because I almost lose my patience.
    Regards Darek.
  • #2 16260575
    wojtekcichy
    Rate: 17
    In a Ford with an automatic gearbox, when the selector stick is set to "P", the controller does not allow it to spin above 3000 revolutions.
    Check if the computer sees the stick shift from P to D?
    Only throttling does not fit here, because normally you should be able to step on the gas and it should smoothly screw into 3,000.
    If the crankshaft sensor is damaged, you would rather not fire it.
  • #3 16260639
    bsv2001
    Help: 26
    Rate: 183
    MAP sensor- As importance in diagnostics
    there may be a catalyst
  • #4 16260674
    Matylda_26
    Help: 6
    Rate: 45
    What's this nonsense for? Why do you write if you don't know each other?
  • #5 16260702
    Biturbo
    But I do not have the error of too low effectiveness of kata or similar.
    When it comes to the rotation lock at the machine, I would have a smooth rotation to 2,500 and it would hold nicely and it starts to tip and drop off the rotation.
    While the candles are tinted black, they are dry.
  • #6 16260748
    wojtekcichy
    Rate: 17
    @ Matylda_26 I had a Ford and the 4-speed CD4E gearbox is limited to 3,000 revolutions in the Parking lot.
  • #7 16261345
    bsv2001
    Help: 26
    Rate: 183
    will disconnect the catalyst
    i MAP sensor- As importance in diagnostics at idle 320-340 - norm
    200 .... or 400 ... problem
  • #8 16261458
    Matylda_26
    Help: 6
    Rate: 45
    I dare say you didn't have a Ford or you can't read the tachometer.
  • Questioning 16382° ignition advance reading on cold engine
    #9 16264128
    Biturbo
    Screenshot of the actual values after starting the engine a few minutes.
    Link
    Screenshot of actual values on hot engine
    Link
    On a cold engine to about 50 ° C, I have a strange ignition advance reading. 16382?
    I don't know if it's an Autocom analysis error or something with the sensor.
    I will replace the MAP sensor and shaft sensor today and see.
    Shaft pulley with sensor crown checked.
    No dents etc.
    The driver sees the gear shift in AT
  • #10 16264169
    bsv2001
    Help: 26
    Rate: 183
    you need to do ignition advance test with oscilloscopes
    There may be a problem with ignition advance
  • #11 16266954
    Biturbo
    Today, i.e. yesterday evening, I checked additionally, replacing it
    Candles - no change
    Crankshaft position sensor new - unchanged.
    New MAP sensor - no changes
    Camshaft sensor - no change.
    I set the timing to locks, it was maybe 2 degrees out - no change.
    Today I will replace the throttle position sensor.
    If it doesn't work, I take the driver to check and this will be the last thing I will do to find out the cause.
    I will definitely write back as soon as I or another person determines what is wrong with this car.
    Greetings interested in the topic
  • #12 16268747
    bsv2001
    Help: 26
    Rate: 183
    swap sensors - it makes no sense
    You have to do everything manually:
    1 Measure fuel pressure
    2 Catalyst
    3 EGR
    4 throttle cleaning and adaptation
    5 FSA 720- ignition
    6 Crankshaft sensor-synchronization
    7 air leak
    8 .....
    Ford IDS diagnosis
  • #13 16269581
    Biturbo
    2 Catalyst
    3 EGR
    5 FSA 720- ignition
    7 air leak
    8 .....
    Ford IDS diagnosis
    Buddy bsv 2001 you do not read exactly what I wrote /
    ad 1: Fuel pressure measurement - I wrote that it is the same on gas.
    ad 2: Catalyst clean. The same on the unscrewed exhaust.
    Ad 3: Clean channel, valve and properly functioning valve.
    ad 4: The entire manifold and damper are washed. The only adaptation I heard about in this model with a cable throttle is disconnecting the battery for some time. battery connection. starting the engine and idling.
    19% throttle opening at idle on a hot engine.
    ad 5: I will ask for this station after other mechanics.
    ad 6:?
    ad 7: I think I'll go to the Ford and ask for a full computer diagnostics.
    And with replacing sensors, it is the fastest way to act as they are identical on the shelf and you only need to plug in and you already know whether it is it or not.
  • #14 16352035
    Biturbo
    Diagnosed fault.
    One day I decided to take the car to an electrician. I get in, turn the key and try to start.
    Does not light.
    Characteristic sound of lack of compression when turning the starter. He was catching something on two cylinders but these were just such sneezes.
    Compression measurement from 4 to 9 atmospheres.
    Reasons:
    Two, in fact.
    Timing belt tensioner fully extended. No synchronization.
    After inserting the camera through the candle hole, I found two delicate traces of suction valves on the 4th and 1st cylinder. Such thin croissants. Those who dismantle the engines know what I am talking about.
    After removing the head, it turned out that the sockets and badly fitting exhaust valves were burned out anyway.
    Generally a lot of carbon deposits and a very brown color of the engine inside.
    The customer mentioned oil consumption and no leaks after stopping the car.
    Engine for overhaul.
    That's it, I greet all concerned.
The discussion revolves around a Ford Mondeo MK3 2.0 Duratec with an automatic transmission experiencing a throttle limitation, where the engine fails to exceed 3,000 RPM. The owner reports smooth operation up to this point, but upon further throttle application, the engine chokes and loses speed without triggering any error codes. Various components have been checked or replaced, including spark plug wires, ignition coil, EGR valve, MAP sensor, and throttle position sensor, with no resolution. Suggestions from other users include checking the gear selector position, ignition advance, and performing a comprehensive diagnostic to rule out issues with the catalyst and fuel pressure. Ultimately, the owner diagnosed a significant engine issue related to timing and compression, leading to an engine overhaul.
