VW Golf III - Chokes when you add gas. It does not keep turning and goes out.
Jagger25 5418 4
  • #1 16493777
    Jagger25
    I have a golf III 1.8 90KM.
    The car sometimes chokes / jerks when adding the gas and only then accelerates. When braking or pressing the clutch every now and then the revs drop so low that it barely zips, there is no rule as to when this will start to happen. It can break for a week and then ride without any problems for the second week :|
    The second problem occurs after rain. Whenever it gets wet, it suddenly starts jerking strongly and goes out. And it will either fire the next day or in 5 minutes and it will continue to jerk and go out. I will add that I have already replaced the candles, cables, dome, finger, hall sensor and the entire ignition apparatus.
    Could something be causing the alternator running low? I heard that it can be the cause of the fading and undulating revolutions that can be noticed when stationary.
    diesel022782
    Help: 13
    Rate: 116
    I will tell you right away that it is not an alternative, the symptoms are also suitable for fuel supply, sea relay or pump, take it into account
  • #3 16495405
    Jagger25
    I will add that when braking, his revs drop so low, just turn it off and fire it and it will be fine for some time: /
  • #4 16495529
  • #5 16501242
    Jagger25
    koleś kit wrote:
    There may be an adjuster or a contactor in it. Tps out of control or problems with the fuel pressure. I feel the gasman's interference is there gas?
    There is gas, but I have been using gasoline for 4 months because the installation often refuses to obey and I cannot collect myself to the gas supply
    Added after 4 [minutes]:
    From the observations I made today, I can add that all problems such as throttling and stalling disappear when the engine heats up to 90 degrees. The only thing that remains after heating is a very low speed drop when braking and parked (in such a situation I can turn off the engine and start and the revs will be good for some time) and going crazy with moisture.
