Peugeot 307 cc 2005 - Incorrect window control from the driver's panel
_maziech_ 20661 5
  • #1 16552026
    _maziech_
    Rate: 10
    Hi!
    I dig a little in the forums, but I did not find what interests me, namely:
    I recently became the owner of a Peugeot 307 cc from 2005 (pre-lift version).
    The car does not work properly when lowering and raising windows from the level of the panel located in the driver's door.
    When trying to raise the glass using the button, it often goes down instead of going up or rises only a few centimeters and stops responding ... And sometimes (very rarely) I manage to lift it or the button does not want to work at all ... The problem concerns basically the left and right doors when controlling the driver's panel.
    I know that such problems can occur if the battery is disconnected. I did not disconnect myself, but I have recently been the owner. Therefore, before I go to the workshop with a defect, I would like to ask if this is not an option to "re-teach" the glass to work properly?
    Maybe you can do something to make the windows work normally? I will add that from the central button raising / lowering all windows at the same time, everything works smoothly and without problems - the lenses normally rise and lower without jamming.
    If there is such a chance, would someone extremely kindly give me a procedure to go through to check / fix? If not, what could be damaged and what could be the cost of the repair?
    Thank you very much in advance!
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    It should be like Renault. Lower to max windows hold the button, raise to maximum hold windows. However, I suspect you have modules in your door. Look for a replacement and it will become bright.
  • #3 16553254
    _maziech_
    Rate: 10
    Well then two questions:
    1. Can you recommend something with Alledrogo that will fit this car?
    2. Will the quick ones come to life after changing the module, or will you have to 'teach' them by connecting a computer?
    PS Lowering / raising windows with holding and key in the ignition did not help.
    kortyleski
    Help: 957
    Rate: 3860
    The driver's panel got the water soon and that's it. Permanent fault.
  • #5 16553610
    _maziech_
    Rate: 10
    So I ordered a new panel - the replacement is not expensive and I also got the impression that this panel was damaged (about PLN 70 new). I will start with this and let you know after the exchange what effects it brought.
  • #6 16568436
    _maziech_
    Rate: 10
    The window control panel has been changed, everything works. Repair cost = 76 PLN.
    Thank you very much for help.
