Audi A6 2.5 quatro tdi 2003 - Error 18265 load signal from the control engine
zbyszekR. 12888 2
  • #1 16554982
    zbyszekR.
    Hello. I will describe a problem similar to others here, maybe someone had such a problem and dealt with it. When I turn on Drive immediately, it is quite a lot, besides, it shifts clean. R also clean. Traction control lights (ABS, ESP) by the way there was a control injection error so we thought that maybe because of this jerks but after replacing the same thing. The chest was regenerated six months ago, so far it hasn't caused any problems. The error also appeared some engine mount or something like that. Every mechanic thinks differently about this. What to do? Can anybody help I do not want to dismantle the box because it probably does not pay me anymore. Last demolition cost me PLN 4,600 so I'm fed up.
    • Audi A6 2.5 quatro tdi 2003 - Error 18265 load signal from the control engine IMG_7063.JPG (3.75 MB) You must be logged in to download this attachment.
  • #3 16555475
    mercedesik
    Help: 80
    Rate: 522
    In your case, this error may also indicate an alternator, I once gave a regulator with a replacement and this error occurred. At the same time, the communication line between the engine control unit and transmission may also be damaged.
    Diagnose car with vag, vasem, vcdsm.
    The cushion (engine suspension) error can be ignored because it is a system of curing the engine suspension by oil cushions.
